10-14-2021, 09:36 AM | #21 |
Re: Building a 255 from a 221 block, help needed.
And plug the oil hole - as it is not needed with a crab dizzy. I'd also put the early cam/crank gears on it - so the thrust it toward the block and not toward the timing cover.
10-14-2021, 01:29 PM | #22 | |
10-14-2021, 02:05 PM | #23 | |
The pickup you need is the truck pickup (the one from Speedway) - which is what you'd use with 39-48 oil pans. I usually use a true 'Mellings' pump - not a Speedway knock-off. In a prefect world, a NOS original or high quality used pump is a great way to go. If you use the later pump, then "stretch" the oil-pressure relief spring in the front of the block about 3/8" -- this makes the rear relief spring "the boss". The original 39-48 pumps did not have the relief valve that the 49-53 ones have. |
10-14-2021, 03:06 PM | #24 | ||
I do have one mercury cam, marked 8CM 2. Also have 5 earlier cams. 91A ; 17 ; 59t ; 2 ; 21A. Which is the best cam to use? Which is the best mercury cam? |
10-14-2021, 06:20 PM | #25 |
Here's the old thread how I did it, with help from the guy's here. https://www.fordbarn.com/forum/showthread.php?t=213786
