03-13-2011, 07:20 PM | #1 |
Tire Pressure
What pressure should I run in the 30X3 tire, and how much in the 30X31/2 Thaniks in advance.
03-13-2011, 08:11 PM | #2 |
Re: Tire Pressure
60-70 lbs.
03-13-2011, 09:12 PM | #3 |
Re: Tire Pressure
Sounds high Jack. Doing some further checking. So far 50 to 55 seems the norm. I run 50 in the 3 1/2's.
03-13-2011, 09:20 PM | #4 |
Re: Tire Pressure
My 30x3 1/2 called for 70.
03-13-2011, 09:20 PM | #5 |
Re: Tire Pressure
I've had a bunch of 30" Ward's Riverside tires on the road over the years and they were always happiest at 65#
03-13-2011, 09:23 PM | #6 |
Re: Tire Pressure
03-14-2011, 08:24 AM | #7 |
Re: Tire Pressure
The rule of thumb is generally 20 psi per inch of tire width for clincher tires -- 3 1/2 X 20 = 70 psi.
With really good rims & very sound tires you can try to run less but the risk of heat & rim cuts increases as pressure decreases. |
