Old 04-18-2020, 06:49 AM   #1
harvest
harvest's Avatar
Default Any Mfg's Make 1949 Mercury Woodie Fuel Tanks?
Any companys out there make 49 merc Woodie fuel tanks? I know they are different than the 49 cars. Thanks for any info.
harvest is offline   Reply With Quote
Old 04-18-2020, 09:10 AM   #2
sawzall
sawzall's Avatar
Default Re: Any Mfg's Make 1949 Mercury Woodie Fuel Tanks?
IN a word NO...
unless 49 is unique.. it used a rectangular tank that was also used in 1950 wagons (and 51?) the tank itself is the same as the 1946 -1948 ford car tanks..
HOWEVER the filler inlet pipe is at a SLIGHTLY different angle..
Years ago i had a 1950 wagon parts car,
someone had contacted me about this problem, but the tank in the car I had was BAD, however comparing it to the 46 car tank I had, I knew they were very very close.
I suggested at that time the best course of action would be to modify a new tank to fix this problem.. unfortunately I don't know if that problem were ever resolved..
Pennsylvania has two seasons. Hershey week, and everything else https://sites.google.com/site/eastcoastwoodies/
sawzall is offline   Reply With Quote
Old 04-18-2020, 09:31 AM   #3
39portlander
39portlander's Avatar
I would try and contact Tanks inc in Iowa, if currently operating. They might have what you need, I went with a larger gallon poly tank for my 39 and the fit was perfect and the extra volume is a nice to have reserve.
Good luck and let us know how you make out.
39portlander is offline   Reply With Quote
Old 04-18-2020, 09:45 AM   #4
philipswanson
Should be the same as 49-51 Ford/Merc wagons. These have the same platform. Should be able to find one on a parts car. Corrosion can be repaired and/or coated over. Go west young man. A custom tank won't fit right, have sender problems and cost big bucks. Join the NWC (National Woodie Club) and put a free add in their classified. You'll want to join anyway.
philipswanson is offline   Reply With Quote
Old 04-18-2020, 09:47 AM   #5
woodiewagon46
As 39portlander mentions, Tanks Inc, 877-596-3842, www.tanksinc.com might nave something available. I know they make '41-'48 Ford, '39-'48 Mercury and '49-'51 Mercury car tanks. I do know however that Woodies are a different animal. If the '46 Ford tank will work with modifications as Jeff mentions that might be the way to go.
woodiewagon46 is offline   Reply With Quote
Old 04-18-2020, 12:08 PM   #6
TJ
TJ's Avatar
Call Rick's Tanks in El Paso , Texas. He makes custom tanks for all kinds of early cars. He can probably make a pattern from your old tank and make you a new one. www.rickstanks.com. Phone# 915-760-4338
Old 04-18-2020, 12:16 PM   #7
34pickup
34pickup's Avatar
Wink Re: Any Mfg's Make 1949 Mercury Woodie Fuel Tanks?
Personally, I would not use a fuel tank made out of wood......
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 04-18-2020, 06:24 PM   #8
harvest
harvest's Avatar
Appriciate all the heads up for info the fuel tank. I actually do have a 49 merc woody fuel tank in very good condition that is clean inside and was pulled from
a car in 1980. Its been kept in my garage storage since and i was trying to figure out if its worth selling. If there is no companys that are making them, i guess i have something worth listing/selling. thank you all for the info.
