Old 03-17-2019, 05:56 PM   #1
Graeme / New Zealand
Graeme / New Zealand's Avatar
Post Wheel alignment specs for 1948 car
I need to get alignment done.Can anyone please give me the specs?
Thanks
GB7
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 03-17-2019, 06:12 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Wheel alignment specs for 1948 car
1/8" toe in. No other adjustment normally required. If your axle is bent, that's a different story, and can only be adjusted by certain truck suspension shops.
Alan
Old 03-17-2019, 08:26 PM   #3
19Fordy
19Fordy's Avatar
The above info is incorrect. The toe in for 1948 Ford car is 1/16 in.
Caster setting is +41/2 degrees, Camber is + 1/4 to 1 degree, King Pin Inclination is 8 degrees, King Pin Dia. is .812 in.
Source: 1935 to 48 Motor's Repair Manual Page 440.
Old 03-17-2019, 08:39 PM   #4
Talkwrench
Talkwrench's Avatar
I think anywhere between those to figures is fine BUT are your tyres radials or crossplys?
You can do it yourself . I just made this up for doing it .
File Type: jpg 14480577_10154550348788064_6817720989665221886_o.jpg (40.7 KB, 55 views)
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 03-17-2019, 10:29 PM   #5
51woodie
51woodie's Avatar
19Fordy has the right toe in number as listed in the 39-48 Service Manual. I took my 46 Super Deluxe to the local Ford dealer to have the toe in checked, and supplied the specs. The Technician had to convert the 1/16" to degrees, as their alignment computer worked in degrees.
51woodie is offline   Reply With Quote
Old 03-18-2019, 01:19 AM   #6
Thanks for your help
Gb
Old 03-18-2019, 11:22 PM   #7
To update had a pro alignment done today. Best $69 i've spent in a while. Toe was way out noticeable difference in the way the car drives
GB
Old 03-18-2019, 11:25 PM   #8
Tinker
Tinker's Avatar
For reference, do you know what degree they used?
Old 03-19-2019, 12:46 AM   #9
Tink . Toe 0 degree.01
GB
