01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
Clearance between Piston and head???
The piston hits the head with no gasket so how much should I take off the head inside the combustion chamber on the head. This is a Z head.I think I'm a little to close to be safe.It don't hit with a head gasket?My brother Mordecai got mad and got in his T and went home.He scared of the head to close he says? |
01-01-1970, 12:00 AM | #2 |
Guest
Posts: n/a
Re: Clearance between Piston and head???
If you put strips of clay on the top of the piston than put the headgasket and head on give the crank a turn and it will tell you what the clearance is |
