Old 02-21-2021, 02:58 PM   #1
Wehill99
Wehill99's Avatar
Default 1936 pickup bed frame question
Can anyone else with a 1936 pickup provide some pictures of the passenger front of the bed frame? As you can see in my pictures the frame is broken out inside of the spare tire hole. I have looked around on line and can’t find this feature.
Thanks for you help
File Type: jpg FB05D2EF-01DE-471F-B371-0B383905C740.jpg (84.1 KB, 70 views)
File Type: jpg 150730CC-5540-4528-82A6-1A545BCC428F.jpg (66.9 KB, 67 views)
Wehill99 is offline   Reply With Quote
Old 02-21-2021, 04:02 PM   #2
OldGold360
Default Re: 1936 pickup bed frame question
This is the best I can do for now until my bed comes off the frame. My spare tire bracket hole needs a little help but other than that it should provide what you need. Currently I am holding the bedside to the subframe using screws until I final install it with rivets as it was originally. Hope this helps.
File Type: jpg BD1B9A88-7A54-400C-8074-BCEE7FFD0F64.jpg (51.0 KB, 61 views)
OldGold360 is offline   Reply With Quote
Old 02-22-2021, 10:44 AM   #3
1936 ford pickup
Hello Wehill99,
I hope this photo helps some.
I have a '36 Ford pickup also.
I might add that before I had purchased this bed frame, someone else had done some repairs around the spare tire mounting hole area where it had broken out, that is why there is a horizontal slot in the patched repaired area.
Bruce in California
1936 ford pickup is offline   Reply With Quote
Old 02-23-2021, 08:30 AM   #4
Wehill99
Wehill99's Avatar
Thanks for the help!
