Old 03-31-2012, 10:31 AM   #1
Reddy
Default New cam
Can a cam be installed with the engine still in the car?
Mike
Reddy is offline   Reply With Quote
Old 03-31-2012, 10:40 AM   #2
Jim Parker Toronto
Jim Parker Toronto's Avatar
Default Re: New cam
Yes, but not easily. (Remove rad etc)
Jim Parker Toronto is offline   Reply With Quote
Old 03-31-2012, 10:41 AM   #3
Woodie1
Woodie1's Avatar
Default Re: New cam
It can but it's a lot of work. You'll need to drain the water & remove the radiator, support the engine at the pan, remove the timing cover, remove the oil pan & the flywheel cover at the rear of the pan. You will need to remove the side valve cover & remove all the valve keepers to free the valves to move up & down. Make sure you line up the timing marks on the cam & crank gear & start the removal. You will want to keep track of which lifters drop out so you can make sure they go back with the same valve. There are a number of other things assumed like draining the oil. Hope this gives you an idea of what's involved. I probably missed a few things as well but it can be done.
Woodie1 is offline   Reply With Quote
Old 03-31-2012, 10:50 AM   #4
Reddy
Default Re: New cam
Thank you guys I plan to change oil pump and lifers at the same time.
Mike
Old 03-31-2012, 02:02 PM   #5
pat in Santa Cruz
pat in Santa Cruz's Avatar
Default Re: New cam
I'd pull the engine. I hate working on my back with oil drippin' on my face, in my eyes and all through my hair
pat in Santa Cruz is offline   Reply With Quote
