Old 10-24-2020, 08:36 AM   #1
bmita
Default 32 sedan door latches
hey guys i purchased a 32 sedan awhile back it was a street rod built back in the late 80's they removed the door handles and factory door latches installed door poppers and latches. i am wanting to remove the poppers and install original door handles and latches, would anyone be able to shoot me some pics of how the original stuff bolted up to the door and quarter panel. any info would be much appreciated.
bmita is offline   Reply With Quote
Old 10-24-2020, 09:28 AM   #2
JSeery
JSeery's Avatar
Default Re: 32 sedan door latches
If you look on the inside you might to able to see the weld marks where the original holes were located. Unless a section was removed and a new panel welded in.
