Old 01-01-2015, 04:38 PM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default 59 engine in a 35 pickup
Question and answer. When installing a 59 engine in a 35 pickup, can you use the 59 dual shive front crank pulley with out removing the front shive? Will the front shive clear the cross member. No using front shive, fan off gen. Thanks Walt
Old 01-01-2015, 04:42 PM   #2
36coupe3w
36coupe3w's Avatar
Default Re: 59 engine in a 35 pickup
Walt
The 35/36 ford pickup will fit the 59 block front dual sheave pulley with no modification to the front cross member or pulley
Bill
36coupe3w is offline   Reply With Quote
Old 01-01-2015, 07:02 PM   #3
Walt Dupont--Me.
Thanks Bill, I was dreading setting that pulley up in the lathe and cutting that front shive off if I didn't have to. Walt
Old 01-01-2015, 07:32 PM   #4
Lawrie
Lawrie's Avatar
Walt, they must be different than the 33,had to cut the twin pulley off,(an easy job) but also had to shorten the crankshaft at the front to clear the crank handle guide on the u/bolts.
Lawrie
Old 01-01-2015, 07:48 PM   #5
Walt Dupont--Me.
Hi Lawrie, up to 34 I knew the 59 front shive wouldn't fit, and you had to put 2in. spacers under the 59 front mounts. I also knew the 59 water pump mounts will bolt right to the 35 up cross member with no spacer. BUT, I kind forgot if the 59 front pulley shive would interfear. Walt
