08-16-2018, 09:57 AM | #1 |
slipping out of 2nd gear
1933 model B, stays in 2nd as long as I keep foot on gas once gas pedal released slips out of 2nd into neutral.
08-16-2018, 10:17 AM | #2 |
Re: slipping out of 2nd gear
Possibly weak or broken detent springs in the shift tower.
08-16-2018, 10:21 AM | #3 | |
Perhaps Van Pelt can weigh in? Some guys attempt the "band aid" fix by installing heavier springs in the detent (shift tower) with mixed results. I hate to be the bearer of bad tidings but my betting money rides on an internal (transmission) issue.
08-16-2018, 10:40 AM | #4 |
Worn thrust surfaces on the countershaft cluster gear. Worn bushing on the intermediate gear. Worn synchronizer parts. There are these and other possible shaft & component thrust wear situations that cause it to slip out of the intermediate gear.
When a person lets off the accelerator, the thrust load reverses. If there is enough play in there it will be enough to cause both the mainshaft intermediate gear and the cluster gear to shift a good bit to the opposite thrust direction. This is why the slip out of gear. Reduce the play to minimum and it will function normally. This can require replacement of parts that may look to be in good condition so a person has to know what they are looking for clearance wise. |
08-16-2018, 03:12 PM | #5 |
This can also be caused by case stretch. assemble the main shaft. and measure between the bearing snap rings. Then measure the length of the case. I forget the clearance required but i know it was tight. If the input shaft turned easy it was too loose. Today we use shims to accomplish the same thing. I stopped working on these trans over 50 years ago, just couldn't take the power. However, the later ones are a very good design. We shortened the case by milling of the material from the rear of the case.
08-16-2018, 04:33 PM | #6 |
08-16-2018, 06:25 PM | #7 |
I APPRECIATE ALL YOUR COMMENTS. This is a recent occurrence. It was not doing this when I got the car running several years ago. So maybe something internal snapped?
08-16-2018, 06:38 PM | #8 |
Frank,
I hope you resolved your DL question. My '32 started doing that a number of years ago and I did some research on it and it's pretty much as folks said... wear of components. I'd add that misalignment was possible... which is another way of saying "wear". One area I was told about was wear of the pilot bearing causing the main shaft to get slightly out of alignment. My problem only happens going down a long hill toward my house in 2nd. So now I drive down in 3rd! The first couple times were scary because the hill is steep. When I rebuilt the transmission, the gears "looked good", so I only replaced bearings and spacers. I doubt that I'd do it differently today. I frankly have learned to drive in ways that minimize the symptoms I have with my Fords. |
08-16-2018, 06:53 PM | #9 |
I just rebuilt mine , clearances all checked, new bearings, shafts syncros etc .. went great for the first run but about 50 miles on , damn its doing it again.. Its been getting a hard time as Im breaking the engine in and Im working it hard. Just didnt last for me ..Damn! Doesn't leak though ...lol
Shift fork ?
08-16-2018, 08:03 PM | #10 |
Theres a band-ad fix that no on like but works. There a guy on e - bay that sell a spring and ball caps for the placement in the shift tower ..
I've used them . Pull the shift tower ,pull one shaft and place the spring/ ball caps in between the shafts . It stiffens thing up until it's time to pull the transmission and fix proper ....
"I can't cry as long as I know the Lord has risen " |
08-17-2018, 06:01 AM | #11 | |
08-17-2018, 06:40 AM | #12 |
The '34 will do this occasionally, under the right/wrong circumstances. I remember asking dad about this, and he said it was common... and that some people would install a little 'J' hook near the dash to clip the shifter handle into, in order to hold it into place. I guess it was a semi-effective band-aid. lol
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. |
08-17-2018, 08:58 AM | #13 |
VanPelt sez-- https://www.jalopyjournal.com/forum/...#post-10828925
Wow, I always thought dash hooks were invented to fix this. 8^) Jack E/NJ |
08-17-2018, 11:12 AM | #14 | |
The passage linked above keeps mentioning synchronizers. The topic of that thread involved late 40's/early 50's transmissions. It's my understanding that the transmissions in the '34 and '35 are NOT synchronized, as they need double clutched when shifting. Dad always said they were not a synchronized transmission, and taught me to double clutch when shifting. Are the late 40's/early 50's transmissions synchronized? Or, are the simply incorrectly referring to the sliders and engagement teeth as synchros? As, synchronizers are the brass/bronze blocking rings that provide the friction for the gears to match speeds as the slider engages the teeth on the next gear. Am I missing something here? I've rebuilt several Ford Toploaders, and some other, 60's-80's era transmissions... so i have a pretty good background of transmission basics. Thanks!
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. Last edited by FL&WVMIKE; 08-17-2018 at 11:53 AM. |
08-17-2018, 01:57 PM | #15 |
Looking at the below link, it looks like the pre-1940 transmissions have very primitive synchronizers. They are not the traditional blocking rings found on the later stuff. Starting out in 1938, the commercial stuff looks traditionally synchronized, and sometime in 1940, the cars started using the updated synchros... with the 1946-54 units looking almost exactly like what is found in a more 'modern' Ford Toploader built from around 1964-73.
All I know, is dad's '29 Model A, '34 Phaeton and '35 Cabriolet never felt synchronized, and worked a lot better if you double clutched them. http://www.vanpeltsales.com/FH_web/f...d-synchros.htm
08-17-2018, 02:46 PM | #16 |
Frank: Keep your hand on the shifter..................
Paul in CT |
08-17-2018, 02:50 PM | #17 |
Only problem with that (hand on shifter) or a dash hook, is that it forces the shifting fork against the collar and it slowly wares the shifting fork surface away. Some of the issues with these transmission is because of someone resting there hand on the shifter while driving. It is a good short term solution, but if it is drive that way for an extended distance/time not sure it is so good of an idea.
08-17-2018, 04:50 PM | #18 |
Mine did the same
There is a old fix . Take the top off Pull the second selector rod Make a matching groove opposite the existing grove in the end of the rod Reinstall the rod and then place a shortened dedent piece and spring under the dedent screw cover Effectively gives you a dedent mechanism on both sides of the rod and stopped mine dropping out of gear -Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
08-18-2018, 10:36 AM | #19 |
Some folks convert the early synchro to the late 1939 or 91A type set up on the early cog boxes but the old shift tower never had a shift fork made to work with the 91A synchro sleeve. The quick fix is to install the late type guts and the late type double detent shift tower. The floor has to be modified a bit for that since the tower is in a little bit different position.
The early synchro worked but not as well as the late type with the brass blocker rings to help slow things to the correct rpm for a trouble free shift. On the old types a person has to do the rpm matching by ear to get a decent shift. Double clutching will do the same thing but they can be shifted from intermediate to high & back without grinding if a person gets used to what makes it function the best. Engine braking can't be totally eliminated since it is necessary may times but it can be minimized by utilizing the vehicle brakes as much as is practicable. The engine braking wears on the opposite thrust surfaces inside the gearbox so over time the disconnect of the syncro starts to show up as the clearances increase with wear. Last edited by rotorwrench; 08-18-2018 at 10:42 AM. |
08-19-2018, 08:20 AM | #20 |
I never checked these parts on my transmission tower. Maybe the spring is broken?
I guess I will have to remove the transmission floor plate to get at this. |
