Old 03-05-2024, 02:34 PM   #1
rottenron36
rottenron36's Avatar
Default 39-40 rear window?
I thought 39 was the last year off the double rear window. I saw two 40,s with the the double rear window, and vent windows in the doors. Help me with my confusion. Maybe ford used up the last of the double window cars in 1940. If someone knows the answer,Please let me know? thanks Ron
rottenron36 is offline   Reply With Quote
Old 03-05-2024, 03:41 PM   #2
rockfla
rockfla's Avatar
Default Re: 39-40 rear window?
40 was the last split rear windows in both Ford and Mercury. 41 was the first one piece rear windows in Ford's and Mercury's
Old 03-05-2024, 04:03 PM   #3
19Fordy
19Fordy's Avatar
Split (double rear window) was OEM issue in all 1940 Fords. They also had front door vent windows.
Old 03-06-2024, 09:06 AM   #4
rottenron36
Thanks for the replies! Ron
Old 03-06-2024, 09:07 AM   #5
busmania
busmania's Avatar
Does anyone make anything to eliminate the vent window in a 40?
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
Old 03-06-2024, 09:39 AM   #6
Karl Wescott
Karl Wescott's Avatar
1. A pair of 1937-1939 doors.
2. The internal window felt retainer from a 1937-39, 1937-39 window felt kit, regulators, and bottom glass retaining channel. Then "unmodify" whatever there is at the back of the window opening when Ford changed from 1939 to 1940.
Karl Wescott is offline   Reply With Quote
Old 03-06-2024, 10:28 AM   #7
19Fordy
19Fordy's Avatar
Consider leaving the vent windows in your 40 as they are part of what makes a 40 SO SPECIAL. Plus, they supply refreshing air when driving.
Old 03-06-2024, 08:01 PM   #8
busmania
busmania's Avatar
Yep. Will likely leave it. It was just something I’ve wondered. I have way bigger priorities for the foreseeable future with my build!
