Old 07-20-2023, 12:33 PM   #1
rottenron36
rottenron36's Avatar
Default ford 94 series 59 need help after rebuild
I have a Ford 94 series 59 carb. Taken apart,ultrasonic cleaned, correct flat power valve 7.5, rebuild kit. All on a stock rebuilt .060 59ab flathead. Runs great with my 97 card. 94 carb floods the engine, barley starts, wont idle. Floats set at 1 5/16. with the float bowl full and carb off, if I lean it a little forward, to the front,I can see gas leaking into the lower part of the carb just above both butterflies. I have had it apart so many times trying to figure it out, no luck! Any help even if i'm doing things wrong, Greatly appreciated. Ron
rottenron36 is offline   Reply With Quote
Old 07-21-2023, 08:15 AM   #2
rottenron36
Default Re: ford 94 series 59 need help after rebuild
Found the leaks under the air horns! delete post
