Old 09-05-2023, 11:16 AM   #1
tucker6077
Angry Sudden Discharge
Ok my 1933 Super Mechanics out there, give me your thoughts on this one. Car has brand new battery. All circuits seem to be fine, starts fine until it heats up under the hood then its like trying to start with a mostly dead battery, until the car cools off for 1/2 hour. Then it starts fine. This morning he car started strong but the amp gauge was at full discharge. Do I have a rouge mouse in my garage that only comes out at night ? Others had given me advise but the pointer down at did-charge might be another hint ???????????????
tucker6077 is offline   Reply With Quote
Old 09-05-2023, 01:04 PM   #2
Brian
Brian's Avatar
Default Re: Sudden Discharge
I'd hazard a guess that the cutout atop the generator is stuck in the closed position.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 09-05-2023, 02:32 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
Just the title of this post made me nervous . . . LOL!
Old 09-05-2023, 08:50 PM   #4
34pickup
34pickup's Avatar
I had sudden discharge when I was stationed in the Philippines....☺
Matt 24:36-41
34pickup is online now   Reply With Quote
Old 09-05-2023, 10:16 PM   #5
Eagle43
I think the problem is the starter. It's probably drawing way to much current when it's hot.
Eagle43 is offline   Reply With Quote
Old 09-05-2023, 10:46 PM   #6
tucker6077
The starter cannot be hot, the car was just started ?
Old 09-05-2023, 11:31 PM   #7
tubman
tubman's Avatar
If they are seriously overloaded, they can get hot very quickly, a matter of seconds. The overload can be electrical or mechanical.
How long can you hold your hand on the burner of an electric stove after you've turned it on? (DO NOT try this at home!)
Old 09-05-2023, 11:38 PM   #8
Lanny
Lanny's Avatar
Have your starter checked by a reputable mechanic.
Make sure your starter is grounding to the engine.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 09-06-2023, 12:15 AM   #9
Brian
Brian's Avatar
'but the amp gauge was at full discharge.'
Starter current does not show on the ammeter. If your ammeter indicate[s] a massive discharge, then you have a major short to earth. The generator circuit does not pass through the fuse [which would blow if any circuit it is protecting developed said short]. Therefore, I say your cutout is suspect....unless I'm misinterpreting what you're attempting to describe?
Old 09-06-2023, 07:19 AM   #10
Bored&Stroked
It sounds like two different issues to me . . . one being the starter itself (and or grounding/connections), the other related to the cut-out. Chase them both down - first addressing the discharge issue (as that will drain the battery in a hurry).
Old 09-06-2023, 08:47 AM   #11
deuce_roadster
deuce_roadster's Avatar
It took me a long time to gain the experience and consider there might be 2 problems when troubleshooting what appears to be one. I would check the cut-out first and then the starter and the floor switch that activates the starter. All connections must be clean and tight. It seems like a lot of people don't consider the ground side of electrical circuits. They are called circuits for a reason and the ground side is equally important as the hot side. That floor switch's cable connections are very close to places on the steering column that could short if the switch itself happened to be loose. When you find the problem or problems let us know what it was.
Old 09-06-2023, 11:08 AM   #12
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
