Old 10-15-2020, 02:06 PM   #1
throwback
Default Gear ratio on rearend
What does 9-34 mean on a rearend?
throwback is offline   Reply With Quote
Old 10-15-2020, 02:09 PM   #2
Mart
Mart's Avatar
Default Re: Gear ratio on rearend
Divide 34 by 9 and what do you get?
3.78!
That's a reasonable set o gears.
Mart.
Old 10-15-2020, 02:10 PM   #3
hotrodart
hotrodart's Avatar
9 is the number of teeth on the pinion gear, 34 is the number of teeth on the ring gear. Divide 9 into 34 to get your rear axle ratio: 3.78 nominal (3.777777777 actual)
hotrodart is offline   Reply With Quote
Old 10-16-2020, 05:24 PM   #4
throwback
Thank You!
