12-06-2015, 10:00 AM | #1 |
Radiator/cooling question
We have a 28 Roadster truck in the shop with Model B engine and Schofield OHV engine. Twin carburetors on a Riley intake. This truck runs so fast (80mph+) it is scary. It turns such high RPM's that the radiator can't keep up with the water flow, and spits it out the overflow. There is a new Miller water pump now on the engine, even further increasing the flow. The radiator is clean with no restrictions. Any suggestions on how to stop the overflow?? It reaches a level in the radiator about 2 1/2 Qts. low where it handles the coolant flow in the system. An infrared heat gun indicates it is not overheating. 180 to 190 all over the radiator and engine.
Bob from Northport Northport, Michigan |
12-06-2015, 10:06 AM | #2 |
Re: Radiator/cooling question
You are over filling the radiator. Let it spit out and then don't add any more water.
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
12-06-2015, 10:13 AM | #3 |
1. You may think about installing a temp gauge
2. Stop driving so damn fast
12-06-2015, 10:21 AM | #4 |
Does it have a thermostat installed? If not, a thermostat may flow the slow.
Another option would be to cut down and/or drill holes in the impellers on the water pump.
12-06-2015, 10:28 AM | #5 |
I bought a radiator neck and cap that a guy made up to mount down by the radiator overflow tube. It was pressurized to 2 1/2 lbs. Another fellow bought one at the same time as his car wouldn't retain water. Both of us drove from Barstow to Dallas and didn't lose a drop in mid June. They were made by Denny Specker, he's South Jordan, Utah 801 282 8005. He may still be making them'
12-07-2015, 04:26 AM | #6 |
12-07-2015, 08:52 AM | #7 |
We considered the smaller crank pulley. Thermostat is also a good idea.
Thanks!!!
12-07-2015, 04:42 PM | #8 |
I run a B engine with Cragar OHV together with Miller water pump. After I replaced the radiator with a new Brassworks 10-fin, no more overheating or problems with coolant blowing out the overflow tube. No need for different pulley. I always leave the coolant level below the baffle.
12-07-2015, 04:58 PM | #9 |
Why not a COOLANT RECOVERY TANK?
Bill Cool
12-07-2015, 05:02 PM | #10 |
12-07-2015, 06:30 PM | #11 |
You might check that the radiator has a baffle in it at the top of the tank. Modern radiator shops don't know about Model A baffles and often leave them out.
The baffle should have a hole in it that the overflow tube sticks up through. Tom Endy |
12-07-2015, 11:39 PM | #12 |
Yes, there is a baffle with a hole, and I tried the nail trick first thing. Snyders has a Riley pulley that they say cuts water pump output by 30%. Anyone use one of these??
