Old 03-19-2021, 01:20 PM   #1
1931 flamingo
1931 flamingo's Avatar
Default It's alive.
Hi Folks.
After much frustration on my part and after replacing the battery I finally pulled the cables (Thanks Ronnie Roadster) after jumpering from the battery
to solenoid and ground and it came alive.
Couldn't see it before but the sol end of the cable was wrapped with electrical tape, removed it and the end was corroded. Had the cable cut back to good copper and soldered a new end on. Will install cable tomorrow but it seems like the "gremlin" has been found.
THANKS to everyone who responded with their suggestions.
Much appreciated ! ! !
Paul in CT
Show season is coming.
Old 03-19-2021, 01:41 PM   #2
rockfla
rockfla's Avatar
Default Re: It's alive.
Great to hear the news!!!!
Old 03-19-2021, 02:43 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by 1931 flamingo View Post
Hi Folks.
Paul in CT
So Paul....That SOUNDS like exactly what I suggested in my post (BELOW)......
" I would first disconnect the POS battery cable from the battery. Then, disconnect the NEG battery cable from the SOLENOID post. This is likely the bad/corroded/dirty connection. Clean and wire-brush ALL the wire connectors and the threaded solenoid post. THIS IS THE CONNECTION where the lights, ignition, starter button, horn get their power. Re-connect the wires that you removed and cleaned on that threaded post. Re-connect the NEG battery cable. Now, re-test your very first test with the meter. IF you now have 6v, your problem is solved. "
......in your ORIGINAL thread stating your problem....IS THAT CORRECT? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-19-2021, 04:51 PM   #4
Zeke3
Zeke3's Avatar
Paul, great to hear you found the issue.
Zeke3 is offline   Reply With Quote
Old 03-19-2021, 08:47 PM   #5
1931 flamingo
V8COOPMAN
PM sent
Paul
Thread Tools
Display Modes
