Old 03-13-2021, 09:39 AM   #21
1931 flamingo
1931 flamingo's Avatar
Default Re: Dead
Battery is a year old. Connections clean and tight. Again no lights, fuel pump, etc.
Will try horn today.
The wiring diagram shows a "circuit breaker" in the circuit (obviously ).
Does it "reset" or is it a one time deal.
Thanks for the help/suggestions so far.
Paul in CT
As I previously stated it ran perfect in the garage the day before after sitting since last Nov.
3/19 update, found corrosion on the Neg batt cable at the solenoid as V8COOPMAN said I would. I'm 76 and a stubborn Swede who wears tri-focals. It's alive now.
Old 03-13-2021, 10:02 AM   #22
marko39
Default Re: Dead
Paul in CT
Circut breaker is for the lights and is supposed to reset after being tripped. See if you have 6volts at your ignition switch entering and leaving switch.
marko39 is offline   Reply With Quote
Old 03-13-2021, 10:34 AM   #23
TJ
TJ's Avatar
Default Re: Dead
If you have an old braided type ground strap they can get corroded and cause problems. Even though the ends may be clean at the battery they can still cause a "no start" issue.
Old 03-13-2021, 11:48 AM   #24
marko39
Default Re: Dead
Start with the basics, put 6 volts directly to starter and see what happens .
Old 03-13-2021, 01:47 PM   #25
swedishsteel
Default Re: Dead
Try different battery cables.
swedishsteel is offline   Reply With Quote
Old 03-13-2021, 03:24 PM   #26
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Dead
Wife and I rocked it back and forth as well as we couuld.
Still have 6.3 volts at the batt and to the sol. Everything else id dead, no lights, elec fuel pump, etc.
Any new thoughts??
Paul in CT
Paul....This is a pretty simple circuit to troubleshoot. And you have one BIG clue already going for you......EVERYTHING is dead! Likely, you have one bad connection that needs cleaning/tightening. I take it that you have a volt meter, as you said you verified 6.3v at the battery. So, lets do a methodical troubleshoot using your volt meter.
Put your meter on the "DC Volts" range. I'm assuming that you are still POS Ground.
1st.....Place POS meter probe on the HEAD next to where it grounds on the engine head bolt (or wherever the ground is connected). Place the NEG probe on the big nut on the solenoid that the NEG battery cable connects to. Your meter should read about 6v. IF it DOES NOT read 6v (and I'd be surprised if it does), we are very close to finding the problem.
IF your meter does NOT read the full 6v during that check, there are only FOUR connections that could cause that problem. I would first clean and tighten the two BATTERY connections, as they are the easiest to R&R. After doing those two battery connections, re-check the original check with voltmeter to determine whether you now have a 6v reading.
IF you STILL do not have 6v reading, I would first disconnect the POS battery cable from the battery. Then, disconnect the NEG battery cable from the SOLENOID post. This is likely the bad/corroded/dirty connection. Clean and wire-brush ALL the wire connectors and the threaded solenoid post. THIS IS THE CONNECTION where the lights, ignition, starter button, horn get their power. Re-connect the wires that you removed and cleaned on that threaded post. Re-connect the NEG battery cable. Now, re-test your very first test with the meter. IF you now have 6v, your problem is solved.
IF you still read less than 6v (or even zero volts), the only suspect point left is the GROUND connection on the engine for the POS battery cable. R&R that connection. Clean/brush as necessary. Re-connect, and measure with meter from that GROUND point to the NEG post on battery. You should see 6v. If so, your problem is solved.
IF you still see any reading much below 6v, then you need to find a better boy than me! But I have faith!! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-14-2021, 09:51 AM   #27
1931 flamingo
Default Re: Dead
V8COOPMAN
Thank you for the detailed instructions. Will do ! !
Thank you to all the other contributors to my problem.
What's baffling to me is it ran the day before this happened............
Paul in CT
Old 03-14-2021, 10:50 AM   #28
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Dead
V8COOPMAN
Stuff happens! If we lived in a perfect world, these old used cars would keep on ticking forever! Let us know how it turns-out. DD
T5 W/TORQUE TUBE
Old 03-14-2021, 11:07 AM   #29
JSeery
JSeery's Avatar
Default Re: Dead
V8COOPMAN
Paul in CT
Not that unusual. When something becomes borderline, it can become like an on/off switch. I it just "good" enough one day and not the next. Don't let that cloud your trouble shooting, step-by-step is the way to go.
Old 03-14-2021, 02:29 PM   #30
1931 flamingo
Default Re: Dead
Thanks JSeery.
Too cold today, tomorrow looks the same. Will run the checks as soon as I can get out there again.
Paul in CT
Thread Tools
Display Modes
