Old 06-05-2019, 09:05 AM   #1
Rockbass
Rockbass's Avatar
Default Car Shakes
Hi Everyone,
Car is 1947 ford flathead tudor new to me. Car shakes above 55 mph and decrease only slightly at 70 mph. Had all 4 tires balanced, no change. Steering wheel does not shake. Front end feels nice and tight. What do I check next? Thanks in advance for your input.
Rockbass is offline   Reply With Quote
Old 06-05-2019, 09:18 AM   #2
RalphM
RalphM's Avatar
Default Re: Car Shakes
Not as simple as my answer, but check everything. King pins to steering box, any amount of wear above specs can cause it. And I’ll probably take flack for this, but
If all else fails, install a stabilizer.
RalphM is offline   Reply With Quote
Old 06-05-2019, 09:26 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
With the car in neutral and out of gear, rev the engine to the appox speed where shaking occurs to see if its in the flywheel, clutch and associated parts.
Jack the rear wheels off the ground and run thru the gears to check drive line and associated parts. (jack stands recommended)
Old 06-05-2019, 09:27 AM   #4
chap52
chap52's Avatar
Jack up front end and give the wheels a good back and forth, top/bottom, front/back and determine if there is any play. I know you said that it is tight, but check again.
In the Southwest if we leave a car parked on a slope or in the hot sun sometimes it takes awhile for the tires to return to round. Works just the same in cold country. Especially if tires are old and dry.
Do as suggested and check pitman arm and all front end components with the car front end off the ground.
OK, I'll join RalphM on the hit list. A stabilizer is a band aid but it is good until your ready to dig into the front end.
Enjoy the adventure, Chap
chap52 is offline   Reply With Quote
Old 06-05-2019, 10:10 AM   #5
50fordcoupeman
50fordcoupeman's Avatar
For whats it worth, I had a similar once but with a little different symptoms. It ended up being a broken motor mount. Good luck!!
50fordcoupeman is offline   Reply With Quote
Old 06-05-2019, 10:10 AM   #6
hook00pad
It could easily be a bad tire. They will balance out even if they are not round. How old are your tires?
Al Hook
hook00pad is offline   Reply With Quote
Old 06-05-2019, 10:41 AM   #7
19Fordy
19Fordy's Avatar
What happens when you move the rear tires to the front?
Are your backing plate bolts tight?
Check all the bolts and nuts related to your front suspension including the condition of the rubber insulator inside you front wish bone ball cap at the X member.
Old 06-05-2019, 10:55 AM   #8
JSeery
JSeery's Avatar
Also, how were the tires balanced? Need to be checked on the car if they continue to be an issue, but it is sometimes difficult to find someone with the equipment to do it. There can be lots of tire issues, what make of tire are they?
Old 06-05-2019, 11:01 AM   #9
deuce_roadster
deuce_roadster's Avatar
Tires can balance on a slightly bent rim. Make sure none are bent. Also it is a long shot but a bad wheel bearing could do this with perfectly balanced tires.
I would double check every thing that turns or pivots in the suspension, including the shackles.
Old 06-05-2019, 01:16 PM   #10
Shu47
Shu47's Avatar
I think the key point the OP made was the steering wheel does not shake. From my experience, normally a front end problem will be transmitted to the steering wheel. I think that 55 MERC-CT and 50fordcoupeman have the right ideas.
Shu47 is offline   Reply With Quote
Old 06-05-2019, 03:21 PM   #11
FlatheadTed
FlatheadTed's Avatar
Greasing the front U joint of the drive shaft is another option ,I had a vibration on my 35 and this helped .Takes a pint ,this can also help the front Torque Tube roller bearing ,they have been known to seize from lack of lube,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-06-2019, 05:04 AM   #12
adileo
adileo's Avatar
Al Hook
Agree this was the case with my 39. Replaced tires and smooth at all speeds.
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 06-06-2019, 07:57 AM   #13
19Fordy
19Fordy's Avatar
As a last resort, check the bolts that secure the steering box to the frame.
Old 06-06-2019, 10:57 AM   #14
alanwoodieman
2 second flathead ted, had a 36 do the same thing. but I would check the rear tires for bad cords--ie tire coming apart!
alanwoodieman is offline   Reply With Quote
Old 06-06-2019, 11:26 AM   #15
Rockbass
Rockbass's Avatar
Thanks everyone for your replies. The tires are at least half worn so I am going to recheck them.
Old 06-06-2019, 01:20 PM   #16
JSeery
JSeery's Avatar
I don't remember what it's called, but there is a tire/wheel test where they apply pressure to the tire will it's spinning.
Old 06-06-2019, 05:19 PM   #17
RobR'35
RobR'35's Avatar
"Road force" is what I believe the test is your thinking of.
RobR'35 is offline   Reply With Quote
Old 06-06-2019, 05:42 PM   #18
JSeery
JSeery's Avatar
Yes, believe that is it. I have never used it, but there are a lot of reports of it identifying issues.
