Old 09-21-2021, 02:37 PM   #1
BashawT
Default Help Identifying Part Please
Afternoon,
Can someone please help me identify the part in the attached photos. I've been going through and blasting and painting parts and I came across these in a bin (unmarked). There seems to be a rubber seal attached to it.
Thanks in advance!
-Travis
BashawT is offline   Reply With Quote
Old 09-21-2021, 02:41 PM   #2
Gary Karr
Gary Karr's Avatar
Default Re: Help Identifying Part Please
These are your window anti-rattler strips that are to be mounted under your garnish moldings to prevent the window glass from rattling.
Gary Karr is offline   Reply With Quote
Old 09-21-2021, 02:48 PM   #3
BashawT
Thank you!
Old 09-21-2021, 03:10 PM   #4
McMimmcs
McMimmcs's Avatar
now you owe Gary half the selling price! [QUOTE=BashawT;2058803]Thank you![
Old 09-21-2021, 07:55 PM   #5
700rpm
700rpm's Avatar
I have an original pair of these, and the rubber is hard as steel. Is there replacement rubber available? I don’t have any current supplier catalogs or internet access.
I like to keep parts original and restore them when I can, but it may make more sense to replace them with new repro.
Ray Horton, Portland, OR
Old 09-22-2021, 10:02 AM   #6
Will N
Will N's Avatar
You do have internet access because you were able to post a comment on this thread. Brattons has these anti- rattlers: https://www.brattons.com/WINDOW-ANTI...uctinfo/31360/
Will N is offline   Reply With Quote
Old 09-22-2021, 10:18 AM   #7
KGBnut
KGBnut's Avatar
It has been a couple of years, but I seem to remember that I had a hard time getting the repops to fit right. I took my originals and put in new rubber scavenged from a windshield wiper. I will have to look at them again and see.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 09-22-2021, 10:20 AM   #8
Gary Karr
Gary Karr's Avatar
The easiest way to replace the old rubber with new is to use a propane torch and burn the old out, then clean it well with a wire brush. Then, after painting them, install the new rubber by pulling it through from one end. This can be done carefully without kinking them so that they can be reinstalled in your car.
Old 09-22-2021, 10:28 AM   #9
katy
katy's Avatar
The rubber made for shower doors might be an option.
Old 09-22-2021, 02:43 PM   #10
frank55a
Both Bratton's & Snyder's and probably most of the rest of the Model A parts dealers carry the replacement rubber for you original strips. Bratton's has the rubber (part #31410) for $1.50 per door & Snyder's has the rubber for $1.25 per door. I have replaced the rubber in several strips.
I think I may still have a few of the original strips stashed away someplace, I have no need for them now, if I run across them I will list them on the swap meet page. If someone needs some PM me and I will look for them.
frank55a is offline   Reply With Quote
