Old 08-07-2021, 09:44 PM   #1
will.rynerson
will.rynerson's Avatar
Default Need Installation instructions Glove box 45 Ford pick up
Hey guys I am looking for some help on installing my glove box and box bumpers. Wondering if somebody has instructions out there.
Thanks,
Will
will.rynerson is offline   Reply With Quote
Old 08-08-2021, 08:16 AM   #2
TJ
TJ's Avatar
Default Re: Need Installation instructions Glove box 45 Ford pick up
The bumpers fit into the holes at the top of the opening in each corner. the cardboard box should have some small metal plates that are in the edge of the box and are set up to take screws that come with the box. The the box slides over the inner metal lip of the opening and the screws go through the holes in the metal lip and into the small metal plates in the glove box.
Old 08-08-2021, 08:21 AM   #3
will.rynerson
TJ,
Thank you. I figured it was easy. Oh, does the glove box door and spring mount first?
Thanks,
Will
Old 08-08-2021, 02:20 PM   #4
TJ
TJ's Avatar
It's been awhile, but as I recall the glove box goes in first. I'm thinking that the bottom of the box sits on the inside of the lower lip and then the door hinge sandwiches the bottom of the box between the hinge and the metal lower lip.
Old 08-09-2021, 08:18 AM   #5
will.rynerson
That makes sense. I appreciate your help.
Thanks,
Will
