Old 07-20-2021, 04:35 PM   #1
Tod
Default Stock top crow foot head, again
The 3rd sample casting proved even better than the first 2, which are in the hands of builders. I made 4 more prototypes and here is the first one of those machined. These are around 7:1 (just a bit over).
Tod
Tod is offline   Reply With Quote
Old 07-20-2021, 05:01 PM   #2
mercman from oz
mercman from oz's Avatar
Default Re: Stock top crow foot head, again
Very nice looking Heads. Well done.
Old 07-20-2021, 09:20 PM   #3
updraught
updraught's Avatar
I was wondering how you could have a 7 to1 without a spark plug recess ...
updraught is offline   Reply With Quote
Old 07-20-2021, 10:33 PM   #4
alexiskai
alexiskai's Avatar
Underside of my Winfield 7:1, for comparison.
Old 07-21-2021, 07:21 AM   #5
deuce5wndw
deuce5wndw's Avatar
Very nice work Tod!!
deuce5wndw is offline   Reply With Quote
Old 07-21-2021, 07:22 AM   #6
Tim Ayers
Looks great, Tod.
Old 07-21-2021, 03:30 PM   #7
Tod
All 4 of the next samples have been machined and they came out nice. I think all 4 of them are already sold, but I will be making a batch for the next buyers as soon as I have at least a dozen to make.
Tod
Old 07-21-2021, 11:15 PM   #8
GeneBob
This is very interesting, (and cool). I have not seen that shape before but I don't know a lot about the different shapes, just that there are several. Can you explain the advantages of this combustion chamber compared to others? Thanks.
GeneBob is offline   Reply With Quote
Old 07-22-2021, 05:08 PM   #9
Hotrodfil
Hotrodfil's Avatar
Liking that Tod.
The stock 14.9hp head has the sparkplug recess like that.
Hotrodfil is offline   Reply With Quote
Old 07-22-2021, 05:45 PM   #10
Tod
Originally Posted by Hotrodfil View Post
Liking that Tod.
It is a proven chamber. I used this on my B heads.
Tod
Old 01-05-2022, 12:55 PM   #11
Mikes Garage
Mikes Garage's Avatar
How can I order one of these heads?
( price and estimated delivery date)
Mikes Garage is offline   Reply With Quote
Old 01-05-2022, 01:04 PM   #12
Y-Blockhead
Y-Blockhead's Avatar
I would guess the best way would be to contact Todd via PM or email thru Ford Barn?
Old 01-05-2022, 03:23 PM   #13
nkaminar
nkaminar's Avatar
The squish area, where the piston comes close to the head, is what give a puff of air that creates the turbulence. The more turbulence the better the performance. The trick is to not cut off the flow of air into the cylinder by the head. Plus, the more centralized the spark plug, the faster the air/fuel will burn which helps performance. I would guess that Tod's head and the Winfield have been designed with these things in mind. The flathead Briggs and Stratton heads were a good design.
File Type: jpg Screen Shot 2022-01-05 at 3.27.29 PM.jpg (11.8 KB, 88 views)
Old 01-05-2022, 05:01 PM   #14
wwirz
Is the head made from gray iron (class 30/40) or ductile iron (60-40-18, etc.)?? Nice looking casting and machining. Are you planning on leaving the foundry logo on the head as well as HT #?
wwirz is offline   Reply With Quote
Old 01-05-2022, 08:52 PM   #15
Mikes Garage
Since I am a "Junior Member", I have apparently not earned the right to send personal messages or emails
Old 01-05-2022, 08:56 PM   #16
Mikes Garage
Since I am A "Junior Member" I apparently have not earned the right to send personal messages or email. Therefore I am unable to contact Tod.
Old 01-05-2022, 10:25 PM   #17
Pete
Pete's Avatar
They were the ultimate for efficiency which equates to maximum hp and gas mileage.
Maximum available transfer area with minimum depth and ideal plug location for fastest flame front speed to full chamber.
Old 01-05-2022, 10:43 PM   #18
Tanglfoot
Hello Tod, yes the Model B 7.1.I received from you last year performs realy well I love it.
Cheers Ross in very warm Mangawhai NZ
Tanglfoot is offline   Reply With Quote
Old 01-06-2022, 08:07 AM   #19
Bruce of MN
Bruce of MN's Avatar
It would be interesting to compare that to the Harley Davidson racing KR750 flatties, which have a similar reputation.
Old 01-06-2022, 09:02 AM   #20
Tod
Mike,
I sent you a private message. I do not spend much time on Ford Barn these days.
Tod
