Old 06-15-2021, 05:55 PM   #1
will.rynerson
will.rynerson's Avatar
Default Bed sides to bed frame rivet 1945 p/u 1/2 ton
Has anyone had the opportunity to put together a bedframe with the bedsideĎs using rivets. I purchased the rivet kit and rivet set tools. But Iím not sure where all the rivets ago thereís five different sizes and head types. So a little help would be awesome.
Thanks Will
Thanks,
Will
will.rynerson is offline   Reply With Quote
Old 06-15-2021, 10:52 PM   #2
GB SISSON
GB SISSON's Avatar
Default Re: Bed sides to bed frame rivet 1945 p/u 1/2 ton
When I bought my 47 tonner the bed was in it's many pieces. It came from California and was in great shape. I used a combination of 1/4 20 and 5/16/18 carriage bolts to re-assemble it. I know you asked about rivets, but the kids and grandkids like the heck out of it and we have a blast driving and riding in it. Just sayin.... I am probably way older than you so I just want to have a good time with my old junkers while I am still here. If you are going to the shows, then that's a different story and listen to those knowledgeble in the proper rivets.
'47 1/2 ton pickup next project, '47 one ton panel 99% stock nearing completion, '47 2 ton with 8ba and 9' script stakebed, '46 1/2 ton woodie project,'59 F350 9' flareside pickup with cummins 6at. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 06-15-2021, 11:34 PM   #3
Grassman
Hi Will, I got my Truck box and components from Northern Classic Trucks, it came with 2 different rivets; 3/8x3/16 round head (10) and 3/8x3/16 truss head (28) the truss heads put the sides to the sub frame and the round heads put the bed front panel to the sides, heads on the outside, don't forget to prep and prime all the surfaces that will be covered up after assembly so you don't have rust. hope this helps, David
Grassman is offline   Reply With Quote
Old 06-16-2021, 09:28 AM   #4
will.rynerson
Thanks so much! Yes priming is done! I purchased a bed rivet kit from C&G Iíve got the rivet set for 1/4Ē and 3/8Ē every helpful.
Thanks
Thanks,
Will
Old 06-16-2021, 09:30 AM   #5
will.rynerson
Thanks for the info, Iím 58 no grand kiddos yet but that can change quickly ;-).
Thanks,
Will
Old 06-16-2021, 10:26 AM   #6
Bob NH
Bob NH's Avatar
When I built the new bed on mine, I used 1/4-20 bolts with knurled bodies ,nuts and lock washers inside and it pulled the subframe and sides together nicely. I had to buy a fairly good amount and have a lot left if anybody would need some ? (I even took time to remove the markings on the bolt heads so they look pretty much like rivets)
Bob NH is offline   Reply With Quote
Old 06-16-2021, 10:55 AM   #7
will.rynerson
Awesome, yeah Iíve already bought the rivets and I think that Iíve got it pretty much figured out as far as for the rivets go now but yeah thank you for telling me how you did it I really appreciate it just in case the rivers donít work Iíll be able to try some other methods.
Thanks,
Will
