Old 04-20-2021, 01:46 PM   #1
Ken Arms
Ken Arms's Avatar
Default charging question
Hey folks, forgive me for asking this on the barn but its were I am comfortable.
For reasons too long to explain I put an electric fan in my 34. The car is converted to 12v and I'm using a typical GM alternator. All works well except I notice when the fan starts and I am at idle the amp gauge drops dramatically. Once I step on it a bit it comes up. I always thought an alternator put out the same amps at slow speed or high. Do I need a higher output alt? Better batterie? I am using a group 35 batterie like a small Honda might use to make room for dual exhaust. The alt is three wire with a diode. I cant recall the fan amp draw but its fairly high. Ken
Ken Arms is offline   Reply With Quote
Old 04-20-2021, 02:17 PM   #2
Zeke3
Zeke3's Avatar
Default Re: charging question
Look up the performance curve for your particular model GM alternator and you will see that the output curve does not flatten out until about 5000 shaft rpm. Just search for your model of alternator performance curve and you should find it.
Zeke3 is offline   Reply With Quote
Old 04-20-2021, 03:07 PM   #3
JSeery
JSeery's Avatar
Something like this.
Old 04-20-2021, 07:09 PM   #4
koates
Not a good idea to have the fan main power cable connected through the ammeter. Connect directly to the main battery cable at the starter solenoid. Less voltage drop there and wont effect other electrical items as much as being through the ammeter. The fan should also be connected through a relay. The alternator will charge at engine idle speed but not any where near its full output. Need some revs up to obtain higher output. Regards, Kevin.
koates is offline   Reply With Quote
Old 04-21-2021, 07:02 AM   #5
Gene1949
Gene1949's Avatar
Couple of thoughts on what I did;
(1) figured total amperage load
(2) sized the alternator accordingly
(3) used the smallest pully I could find on it
I too had a early GM (42 amp) alternator. When I added a late 90s Taurus SVO 2 speed fan and shroud (basically a bolt on), a 800watt stereo amp, halogen headlights and AC I had a huge deficit. Modified the GM mount to fit a later Ford 120? amp alternator and problem solved. The small GM pully I was using fit the late model Ford. Lot of different configurations of the Ford alternator, I forget which one fits (almost) the GM bracket I used on the Merc flatty.
Gene1949 is offline   Reply With Quote
Old 04-21-2021, 07:37 AM   #6
Gene1949
Gene1949's Avatar
one other thing, your system alternator is functioning as it should. If your driving is constant stop and go traffic you should think about an upgrade. I wouldn't be concerned about a fall off sitting at a stop light once in a while. If you attend "cruises" you are going to need an upgrade.
Just my $0.02
Old 04-21-2021, 10:35 AM   #7
G.M.
Ken you are going in the right direction but only have way there. You need
to have a 24 volt statter installed. This isn't expensive. I had it done to two
GM 12 volt alternators and they charge at idle with a standard 39 Ford pulley.
They can do it for 6 or 12 volts, either polarity. Contact Chestnut Hill Electric
in Denver or Lancaster Pa. They also have a place in Ohio. G.M.
www.fordcollector.com
Old 04-22-2021, 09:47 AM   #8
CaliforniaBorn36
CaliforniaBorn36's Avatar
G.M., what is a statter? I did some searching of the internet and could not find the answer. Just curious as I am experiencing a similar issue.
CaliforniaBorn36 is offline   Reply With Quote
Old 04-22-2021, 10:26 AM   #9
G.M.
Statter is the windings inside the outer case or shell. G.M.
Old 04-22-2021, 10:36 AM   #10
flathead4rd
flathead4rd's Avatar
The spelling is wrong. It's STATOR. Look it up.
flathead4rd is offline   Reply With Quote
Old 04-22-2021, 10:42 AM   #11
1948F-1Pickup
1948F-1Pickup's Avatar
Stator-
The stator is the stationary part of a rotary system, found in electric generators, electric motors, sirens, mud motors or biological rotors. Energy flows through a stator to or from the rotating component of that system.
1948F-1Pickup is offline   Reply With Quote
Old 04-22-2021, 02:22 PM   #12
Ken Arms
Ken Arms's Avatar
Thanks all, I ordered a smaller pulley to start out with. As near as I can tell my alternator is rated at 60 amps. I will try the pulley first and post what happens. Ken
Old 04-22-2021, 09:13 PM   #13
CaliforniaBorn36
Thanks all for the info on stator
Old 04-30-2021, 12:47 PM   #14
Ken Arms
Ken Arms's Avatar
Just an update, I tried a smaller pulley and although I do see an improvement the amps still drop when the fan kicks in. I think I may bite the bullet and purchase a high output alternator. Ken
Old 05-26-2021, 12:51 PM   #15
Ken Arms
Ken Arms's Avatar
So, Its fixed, I put I high output alternator on from powermaster but the symptom remained. Once I powered the fan from starter solenoid all is good. I still don't get a charge at idle but I think its just that the flatheads can idle so slow. Thanks Kevin, you were on the money. Ken
Old 05-26-2021, 12:57 PM   #16
JSeery
JSeery's Avatar
Most likely it looks better because you have now bypassed the ammeter, LOL. It's the same as it was, you just can't see it now. The ammeter shows the current flow to and from the battery, but to show that everything has to pass through it.
Old 05-26-2021, 03:57 PM   #17
Wrenchead
How old is your battery? It may be part of the reason/solution.
Wrenchead is offline   Reply With Quote
