Old 04-30-2019, 08:30 PM   #21
Tinbasher
Tinbasher's Avatar
Default Re: The Death Wobble Thing, Brakes
Ok So 5 deg's is what your looking for. I'd check the Radius ball and make sure it not worn. Also that the ball is mounted properly. If the upper plate is worn or missing this will decrease the camber. If all of this is good and solid then you can take the car to a Heavy truck alignment shop that will have the tools to bend the axle.I'd check for worn parts first, then a straight and level frame. If that's all good then go for the alignment work. JP
Tinbasher is offline   Reply With Quote
Old 05-03-2019, 05:37 PM   #22
DHZIEMAN
Just one more tid bit. Got new brake drums and started putting parts together and boing! Had to drive to the Middle of Morgan County out in the middle of Farm country to find a decent machinist with a 50 ton press to swedge the lug bolts in the brake drums! Should be ready Monday!!!! I had thought about just doing it the with a Weld tack of the lug studs to the hub and then slip on the drum. It would work, but not the Henry way! On this, might just as well do it the Henry Ford Way!
DHZIEMAN is offline   Reply With Quote
