Old 07-14-2018, 02:58 PM   #1
CB919ER
CB919ER's Avatar
Default Fan Belt Tension
I've just put a new belt on my Car, and when I start the car I get a bad squealing noise. I can tighten the belt, go for a drive and all is well, but when I park the car for a couple hours and restart it the noise comes back. I'm open to suggestion on correcting this problem.
Thanks in advance
CB919ER is offline   Reply With Quote
Old 07-14-2018, 04:01 PM   #2
Bob C
Default Re: Fan Belt Tension
Are you running an alternator or generator?
Old 07-14-2018, 04:24 PM   #3
denniskliesen
denniskliesen's Avatar
Straight wrapped belt or cogged on the inside radius?
denniskliesen is offline   Reply With Quote
Old 07-14-2018, 04:28 PM   #4
CB919ER
CB919ER's Avatar
I am running a generator
I'm not sure what that mean, I just got a standard replacement from Mike's A-Fordable to replace the 30+year old belt that was about to break.
Old 07-14-2018, 04:56 PM   #5
tinkirk
tinkirk's Avatar
Thanks in advance
tighten the belt
tinkirk is offline   Reply With Quote
Old 07-14-2018, 05:34 PM   #6
Gary WA
Gary WA's Avatar
Not real tight! 1" slack!
www.whidbeymodelaclub.com
Old 07-14-2018, 05:45 PM   #7
WHN
I have had the same problem on and off for many years.
I spray a little WD40 on generator pully in front of belt. That solves the problem.
You don’t want the belt to tight. Enjoy.
Old 07-14-2018, 06:37 PM   #8
Jacksonlll
Jacksonlll's Avatar
Not a tight belt. Puts too much bending load on the fan to pump shaft joint.
Old 07-14-2018, 07:05 PM   #9
Synchro909
Synchro909's Avatar
IMO, over tightening the belt is about the most common mistake owners make. By its very design, a vee belt doesn't heed to be tightened much at all. It wedges itself into the pulley and drives just fine. The more drive needed, the tighter it wedges. I run an alternator and with either a notched or plain belt, I leave about 2" slack when tested between the water pump and the crankshaft pulley. By "slack", I mean no tension AT ALL on my fingers for 2" of movement in the belt.
More tension only cuts out the water pump bearing, which is under engineered anyway, especially with the soft shafts supplied these days.
If it squeals, use some belt dressing or even a little soap.
Old 07-15-2018, 01:42 AM   #10
updraught
updraught's Avatar
If all else fails try a cogged V belt. They seem to grip old worn pulleys better.
https://cdn.shopify.com/s/files/1/11...37289571966664
https://www.youtube.com/watch?v=ypCcKJS0fx0
updraught is offline   Reply With Quote
Old 07-15-2018, 07:31 AM   #11
chap52
chap52's Avatar
I have taken an old bar of soap and rubbed it on the belt/pulley contact area and eliminated the squeak. You can do it with the engine idling or shut off, depending on your health care coverage...Chap
Old 07-15-2018, 08:21 AM   #12
Kurt in NJ
Kurt in NJ's Avatar
The long generator rear bushing can squeak if it crying for lubricant--- and the brushes can squeak
Old 07-15-2018, 09:20 AM   #13
tinkirk
tinkirk's Avatar
Thanks in advance
i have taken a file and with the engine running,carefully touch the edge on both sides, and i mean (carefully!)
had a guy that worked at a Buick dealership years ago show me this trick on a brand new car that was brought back in because of the belt squeaking, he told me it works every time and so far yes it does work
good luck and God Bless
Old 07-18-2018, 10:40 AM   #14
DHZIEMAN
Thanks in advance
I have in my Stuff box a vintage Belt stick that was used on flat belts.
I apply it with engine running carefully. It stops all noise. There is some modern stuff available at car parts stores that does pretty much the same thing.
Model A Ford belts normally are not run real tight (like a banjo string) as the water pump and gen bearing just are not set up for that. Not sure of the right spec but on mine I can move the belt back and forth about an inch or little more, and no squeeks.
DHZIEMAN is offline   Reply With Quote
Old 07-19-2018, 07:16 AM   #15
rocket1
I think the generator pulley and or the fan pulley is worn and the belt is then riding low on the pulley or pulleys,old belt was quiet? compare belts for the angle.
rocket1 is offline   Reply With Quote
Old 07-19-2018, 12:17 PM   #16
J Franklin
J Franklin's Avatar
Did you thoroughly clean all the pulleys? Did you see if there is excessive drag in the water pump or generator? My car charges and cools with over 2" slack in the belt without squealing.
Old 07-19-2018, 01:15 PM   #17
Benson
Benson's Avatar
Are you sure that you do not have a 4L belt installed on Model A's 5L pulleys?
A 4L will ride low in a 5L pulley groove!
Old 07-19-2018, 04:45 PM   #18
Synchro909
Synchro909's Avatar
That’s about where I run mine. No problems and the water pump bearing lasts!
Old 07-19-2018, 04:57 PM   #19
nhusa
nhusa's Avatar
Put some clothes on the belt — I mean belt dressing.
nhusa is offline   Reply With Quote
