04-01-2021, 07:09 AM | #21 | |
Re: Coast to Coast in a Model A
04-01-2021, 03:04 PM | #22 |
77Birdman - I'm located just outside of Hershey! Very convenient for the car show lol!
Nick |
04-01-2021, 03:19 PM | #23 | |
04-01-2021, 04:58 PM | #24 |
This will be an experience of a lifetime! When will you begin and will you post a daily progress report? Wayne
04-02-2021, 08:26 AM | #25 | |
Good luck on your journery. I too would be interested in a daily/weekly recap. Unfortunately I dont do facebook (only assume that would be a good place to post), however my wife is on it all of the time. IF you are going to do updates on there show a link, or whatever its called and Ill have her tune in. |
04-02-2021, 08:36 AM | #26 |
04-02-2021, 09:00 PM | #27 | |
When travelling as the only Model A, I take a fairly comprehensive set of tools. Spanners, screw drivers, pliers etc. I take points, condenser, coil distributor body, cap and rotor button, a water pump and a set of new engine bearing inserts. If I have bearing problems, I can change inserts on the side of the road so I carry enough oil to refill the sump afterwards and a filter. Bearing problems probably mean fragments of stuff I don't want in the oil. I carry some electrical wire, insulating tape, grease gun and oil can. There are of course tyre levers, pump and jack. There is a fan belt, head gasket, torque wrench and the special socket to get to the head nut under the distributor. A tube of high temperature silicone and a stick of epoxy putty go in and a spare fuel filter. I figure the silicone could have many uses including a temporary repair to manifold gaskets. Les Andrews' book is usually in there somewhere too. I pack a 12v LED work light but haven't needed it yet other than some light while we cook dinner! I do not carry a timing gear (the engine has an aluminium one fitted only about 50,000 miles ago) nor do I carry a spare axle. That would mean a spring spreader as well and they are heavy. Now we are down to the fiddley bits like a sachet of waterless hand cleaner, poly tarp, rags etc. The number of my parts supplier is in the phone and I know that in any decent sized town, there is a good chance that if I order before about 3pm, the parts could be there next morning - a couple of days at most. Out in those areas, it is amazing how strangers will offer help with all sorts of problems (not that we have had to ask) so workshop facilities are likely to be available. For example, a Canadian friend touring in a Toyota van broke a tail shaft. He removed the parts and hitched a lift to the next town, only an hour and a half away, leaving his wife with the van. The odd job handy man in that town was busy so my friend went to the pub to wait. By the time the job was done, it was a bit late to expect anybody to take him back so next day, he hitched a lift back, refitted the tail shaft ad drove on. His wife says it was the most peaceful night's sleep she had had in ages! So far, the worst things I have had happen are a broken fan belt (I knew when I left home that it was starting to delaminate), the Model A #3/#4 crossfire issue and the front bearing in a water pump. The first two took about 5 minutes each to fix and the water pump, not much more. (Did I say I carry potable water?) Oh, I just remembered, there was something else. I had reinforced the wheel centres to stop them cracking where they rest against the brake drum but then, the next weakest link started to break. I was pulling the spokes off the rim. A friendly farmer offered the use of his shop so I took off the tyre and tube, drilled a 1/4" hole where the spoke should go, then plug welded it back in place, ground off the rough edges and reassembled. I am still running a couple of those wheels on one of my cars solo. I have since been able to find a a set of 16" wheels (quite rare here) which are stronger. . I run 12 volts so any common electrical item is readily available at any roadhouse. All in all, I leave most of my workshop at home and while I have probably forgotten something, that is about it.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 04-03-2021 at 04:40 AM. |
