Old 05-04-2022, 01:05 PM   #1
jeepguy1948
Default Lowering RPU Box
This may be a really dumb question and I might be missing some obvious answer but here goes. Is it possible either remove or reduce in height the wood (approx 2"X4") that sits between the box and the frame? I would like to bring the fenders down closer to the rear tires.
jeepguy1948 is offline   Reply With Quote
Old 05-04-2022, 01:07 PM   #2
jeepguy1948
Default Re: Lowering RPU Box
And yes, I know that I have to deal with the crossmember and the box floor
Old 05-04-2022, 03:27 PM   #3
Ivan in southeast va.
Ivan in southeast va.'s Avatar
You could change your spring to an 8-leaf spring, but I would leave it alone.
Ivan in southeast va. is offline   Reply With Quote
Old 05-04-2022, 03:39 PM   #4
Herb Concord Ca
Replace your rear spring with Model T rear spring. I got a 2"+ drop in fender to wheel center.
I can't take credit for this it comes from Jim Brieley (sp).
Herb Concord Ca is offline   Reply With Quote
Old 05-04-2022, 04:45 PM   #5
Bob C
If you bring the fenders down what do you do with the running boards.
Old 05-04-2022, 06:09 PM   #6
Keith True
Keith True's Avatar
You are also going to have to renotch the fenders to fit the splash aprons. Also,I don't believe the outside subrails will clear the splash aprons when dropped down.Replacing the rear spring with an 8 leaf roadster spring won't drop it any,but it will make it ride better.i have one in my pickup.The T spring will drop it though.
Keith True is offline   Reply With Quote
Old 05-05-2022, 01:22 PM   #7
Charlie Stephens
I am running an eight leaf rear spring on my '31 RDPU. Fenders are down and ride is great.
Charlie Stephens
Old 05-05-2022, 06:59 PM   #8
Herb Concord Ca
When I mentioned the 2"+ drop, that was just easy to measure the drop. The chassis (bed and all) rides lower. That is what I wanted; I didn't have mess with items mentioned in posts 5&6. Be installed for 3 years and no problems.
Old 05-05-2022, 08:09 PM   #9
jeepguy1948
Well, in my defense I did say it was probably a dumb question. I had only crawled around underneath the truck to see if there were any obstacles. Hence, my question. It did not occur to me that I would have an issue with the splash aprons as I never took the time to consider that. Thanks for steering me straight
Thread Tools
Display Modes
