05-01-2022, 11:54 PM | #1 |
Carb cover
What was the surface treatment on the V8 carburetor cover / cap ???
05-02-2022, 02:06 AM | #2 |
Re: Carb cover
Ford carburetor castings were gold chromate coated. There are instructions on how to do this in the back pages of the Ford Carburetor booklet, but the chemicals are very toxic and need to be used with extreme caution. but it does give a nice gold finish.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
05-02-2022, 06:54 AM | #3 |
Re: Carb cover
If you are asking relative to the original finish on a '35 carburetor, it was plain, not yellow chromate.
05-02-2022, 11:28 AM | #4 |
Re: Carb cover
There is no product available today that doesn’t make your carburetor look like a painted floozie. You’ve heard the one about lipstick on a pig?
Alan |
05-02-2022, 02:37 PM | #5 |
Re: Carb cover
As David has correctly advised, NO gold.
05-03-2022, 06:58 PM | #6 |
Re: Carb cover
What I really want to know is the treatment of the fuel pump cover. I've never seen a cap that wasn't rusty. |
05-03-2022, 07:49 PM | #7 |
Re: Carb cover
Easy; cadmium plated. (Only the answer is easy as cad plating sources are drying faster than a spring shower on hot paving.)
05-03-2022, 08:13 PM | #8 |
Re: Carb cover
Cad plating option? Anyone have a recommendation on a paint that looks like cadmium finish? I would like to paint my aftermarket voltage regulator to look more like the original cad plated cover.
05-03-2022, 08:25 PM | #9 |
Re: Carb cover
Check this out : https://caswellplating.com/electropl...ting-kits.html.
05-03-2022, 09:33 PM | #10 |
Re: Carb cover
Rattle can paint in either matte or dull aluminum duplicate the appearance of cad plating. Not normally seen in hardware stores, but it is available online.
05-03-2022, 10:46 PM | #11 |
Re: Carb cover
Eastwood carries silver and gold Cad paint.
https://www.eastwood.com/ew-silver-c...sol-12-oz.html
Tim Downtown, Ca |
05-04-2022, 07:24 AM | #12 | |
Re: Carb cover
I have tried Eastwood's "cadmium paint" and have not been pleased with the results.
05-04-2022, 09:13 AM | #13 |
Re: Carb cover
05-04-2022, 10:03 AM | #14 |
Re: Carb cover
Thanks guys. I'll find a Rust-Oleum or Krylon rattle can of matte / dull aluminum.
05-05-2022, 08:40 AM | #15 |
Re: Carb cover
I looked on line and at Walmart and could not locate the recommended spray paints. I did find Rust-oleum product # 327907 on the shelf. I sprayed a test and the finish is Matte. Looks like a good match for Cad. It is listed as "metallic aluminum"
