03-03-2022, 09:25 AM | #1 |
36 pickup seat
How is the seat bottom and backrest attached in a 36 pickup? Mine is missing, only the platform remains. What year seats or springs will work? Thanks, Art
03-03-2022, 11:48 AM | #2 |
Re: 36 pickup seat
Hey Art,
Here are some pictures I saved. I’m pretty sure I got them from the Barn posted by another member. The plywood base has holes that located on posts that are part of the seat riser. I think I have others and will post them if I find them. Sorry, but I can’t answer your question on which seat springs will work. I think its safe to assume 35-37 will work, but not sure about later years. I’m sure there is someone here that can. |
03-03-2022, 12:51 PM | #3 |
Re: 36 pickup seat
HELLO....here is a picture of how the seat bottom and seat backrest attach.
Seat Bottom attaches with screws to wooden base. Seat backrest is hinged to Seat Bottom. Seat backrest upper most two vertical posts go inside openings in horizontal railing around backside of cab. |
03-03-2022, 12:55 PM | #4 |
Re: 36 pickup seat
HELLO....here is a picture of my '36 Ford pickup seat bottom and seat backrest.
Sweat bottom attaches with screw to wooden base. Seat backrest is hinged to Seat Bottom. Seat backrest two vertical posts slide up inside openings in vertical railing around inside backside of cab. Bruce in California |
03-03-2022, 01:29 PM | #5 |
Re: 36 pickup seat
I just received a new set of springs from Snyders in New Springfield, OH.
My 35' seat was really shot and the backrest could have been restored with a lot of work removing rust and repainting. They weren't cheap (by my standards), but, they matched my old ones perfectly. Saved a lot of time. They can make many replacements not in their catalog if you send your old ones to them. |
03-03-2022, 04:45 PM | #6 |
Re: 36 pickup seat
The 3/4 inch plywood base has a two rectangle metal plate with 2 holes the diameter of the posts that are part of the seat base. The two holes in the metal plate allow you to adjust the seat -- all of about 1 1/2 inch forward or backward. Not as much as compared to a passenger vehicle anyway. |
