08-21-2021, 05:24 PM | #1 |
Product Review - HF Daytona (Jack) Cross Beam
In trying to find a quicker way to jack up my A, I bought a Harbor Freight cross beam that would lift with two pads about 35" apart instead of just one center saddle. The product is made well, lifts supports 2 ton, and is about $60. All of my old car floor jacks have the saddle with 1 3/16" hole. The cross beam I got did not include an old time, welded on standard saddle pin, but instead a vertical hole drilled through the cross-bar with a a separate bolt-like 7/8" pin that was threaded on one end. When inserted into the cross-bar the threaded end extends only about 3/8", not enough to sit in the saddle hole of a jack. I had to go to the farm store and buy a tractor hitch pin and fabricate the rest of the saddle stud via a black pipe bushing and welding. I don't know what HF was thinking on this one, but as sold the product cannot be used with the older orange HF saddle jacks.
08-21-2021, 05:52 PM | #2 |
Re: Product Review - HF Daytona (Jack) Cross Beam
Typical of most HF stuff
I consider most anything I buy there to be “one and done” I don’t trust their jacks or jack stands. I have them but always put solid hardwood timbers under anything I jack or support |
08-21-2021, 06:42 PM | #3 |
I agree. I use a jack just to lift....then quality jack stands and wood posts for insurance. I buy a lot of HF stuff....couldn't afford all the stuff I have otherwise. I review things and look at them in the store before I buy, but this cross beam was all packaged and neither the box picture or the product description mentioned the saddle pin. Frankly, I was surprised by the fact that this would not work out-of-box on their old jacks.
08-22-2021, 06:21 AM | #4 |
I lost about 2 hrs in the process |
