Old 05-14-2021, 05:58 PM   #1
Oldgearz
Default Front bumper bracket tilts downward
Have a 1930 Coupe and the front bumper tilts slightly downward because the end of the right bumper bracket where it attaches to the bumper is twisted slightly forward, causing the bumper to be leaning forward rather than perpendicular to the ground. Has anyone tried to twist the end of the bracket, and if so what was the shade tree method used?
Oldgearz is offline   Reply With Quote
Old 05-14-2021, 06:34 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Front bumper bracket tilts downward
You might try jacking it.
But I’ve always straightened them in a press
You may need to remove both so as to mirror-image the correct one to the other
Oldbluoval is offline   Reply With Quote
Old 05-14-2021, 07:24 PM   #3
whirnot
whirnot's Avatar
Acetylene torch and a rosebud. Takes 2 minutes.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 05-15-2021, 08:41 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
From experience, I know that straightening the bracket cold while on the car will bend the frame. Get the bracket red hot with a torch, then bend the bracket.
Bob Bidonde
Thread Tools
Display Modes
