04-30-2022, 10:02 PM | #1 |
0.083 over piston rings
I've got a set of pistons 0.083" over stock 3 3/16". Were these made for use after removal of stock sleeves? Any ideas where I can track down a set of rings? Tried hastings and no such luck...
Sometimes, ingenuity gets in the way of sense and sanity. |
05-01-2022, 02:36 AM | #2 | |
Re: 0.083 over piston rings
Will....Did you try contacting Fred Wilner at Southside Obsolete, "barnfind08"(via PM) here on F'Barn? OR James Saccoccio Gotham Auto Parts,LLC 340 Cherry Street Bedford Hills, NY 10507 [email protected] Tel: (718) 878-3699 Coop . |
05-01-2022, 10:31 AM | #3 | |
The availability of those pistons dried up decades ago making them valuable. I do not know whether or not they are now being reproduced.
05-01-2022, 11:38 AM | #4 |
I bought my pistons from Egge for my 8BA. They were their stock 4 ring piston spcl order so it takes a couple of weeks to get them.
Seems like I ran stock Hastings .080 rings, the .003 dia difference shouldn’t translate into a appreciable difference in the final end gap measurement...... Also used total seal to seat the rings.
Tim Downtown, Ca Last edited by CA Victoria; 05-01-2022 at 11:45 AM. |
05-01-2022, 11:45 AM | #5 |
I believe JWL posted that he may have some of the .083" over stuff he'd sell. Might contact him to see.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
05-01-2022, 03:06 PM | #6 |
05-01-2022, 04:24 PM | #7 |
Might as well go to .125 over. @0 more cubs and one point in CR. Angle mill the heads .070 and get another point in CR. Make a nice driver, with good mirage,
Gramps |
05-01-2022, 05:11 PM | #8 |
I had some plus 83 rings from Egge.
Try them may still have them. Phil NZ |
05-02-2022, 07:09 PM | #9 |
Thank you for all the input👍
05-03-2022, 06:50 PM | #10 |
Couple of years ago I got them from Hastings.
