08-11-2021, 05:35 AM | #41 | |
Re: Do I panic? - Rear main oil leak.
Greg, I have been trying to figure out exactly which type of head it is. There are two "marking" on it. One is the letter "R" with a circle around it, and the other is the 1964, which I imagine is the year of manufacture. It looks very much like a stock Model A head. |
08-11-2021, 05:45 AM | #42 |
Well, I just drained the crankshaft oil and the coolant out of Little Willie. The coolant was most clear, with a rusty tinge. No oil noted. The crankcase oil had a small amount of water at the bottom; I imagine no more than a cup or so. (It could be more, but I have no way of accurately measuring it. I think that the coolant was mostly going out the tailpipe, even though we did not see white vapor coming out. In my uneducated estimation, I believe it could have been worse.
So, the next step is what? A boat racing friend suggested filling the crankcase up at least two times with cheap oil, and turn the engine over to get rid of any residual coolant which might cause corrosion. He called it a dry run and something apparently boat racers do, if water gets into the crankcase. That makes sense to me. Obviously, we will pull the head and see what is going on. Given that the car ran well and the compression was still good even with the water in the cylinder, I am leaning towards a "simple" blown head gasket. Or at least I hope so. |
08-11-2021, 05:49 AM | #43 |
I don't feel comfortable working on this by myself, and our local Model A mechanic is busy with other projects for the next several weeks. So, Little Willie will take a rest in our garage until we can work on him.
It will be interesting to see if the oil leaking out of the rear main seal and the water getting into the cylinder and crankcase are related. I imagine they could be. More later. Last edited by philcobill; 08-11-2021 at 05:55 AM. |
08-11-2021, 06:36 AM | #44 | |
We will definitely pull the oil pan. It will be interesting to discover what is going on. |
08-11-2021, 07:08 AM | #45 | |
Did you drain the radiator BEFORE loosening the head nut on distributor cable? If nut is loosened (even one nut) with coolant in radiator there will be a leak. The longer the nut is left loose with coolant in radiator (like over night) the more it will leak. Always drain coolant first. Last edited by Benson; 08-11-2021 at 07:16 AM. |
08-11-2021, 07:20 AM | #46 | |
08-11-2021, 09:00 AM | #47 |
It will be interesting to see if the oil leaking out of the rear main seal and the water getting into the cylinder and crankcase are related. I imagine they could be. More later.[/QUOTE]
In my opinion, there is no correlation between a rear oil main leak and water issues. The rear main leak is probably from either a rear cap that needs to be adjusted, or the babbit has cracked or chipped, or something with the drain tube. One will not solve the other. |
08-11-2021, 09:58 AM | #48 |
