Old 01-27-2021, 10:08 PM   #1
ModelAJim
ModelAJim's Avatar
Default B Pillar Coupe vs Sedan
Guys,
Wondering if the B Pillars are same for a Coupe and a Sedan on a 30-31?
Thanks!
Jim
ModelAJim is offline   Reply With Quote
Old 01-28-2021, 12:47 AM   #2
Fordfan29
Default Re: B Pillar Coupe vs Sedan
The doors are different widths if that helps. What are you trying to do?
Fordfan29 is offline   Reply With Quote
Old 01-28-2021, 08:35 AM   #3
ModelAJim
ModelAJim's Avatar
I'm just seeing if all B pillars are the same for a coupe or a sedan? The post behind the door.
Old 01-28-2021, 11:56 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Jim, the correct term for that is the Quarter Lock Pillar.
The basic answer to your question is they are different. The 45B Coupe uses the A-46680-B/A-46681-B Pillar whereas the 55B Tudor uses the A-56674-B/A-56675-B Pillar.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-29-2021, 08:06 AM   #5
desotoguy
Seems that no matter what the correct term for the part in question, most of us will still refer to the part as THE B PILLAR.
desotoguy is offline   Reply With Quote
Old 01-29-2021, 10:10 AM   #6
Oldbluoval
Oldbluoval's Avatar
Well if you’re trying to look it up in parts list better call it what Henry’s boys called it.
Otherwise it’s a pretty tough search
Oldbluoval is offline   Reply With Quote
Old 01-29-2021, 11:01 AM   #7
Benson
Benson's Avatar
Now I see the question was about 30-31!
Benson is offline   Reply With Quote
