Old 04-03-2016, 11:27 AM   #1
LP
Default 53 Ford Master cylinder leaking
I have recently purchased a 53 Ford Customline 4door with Flathead V8 3 speed.
I replaced the master cylinder and wheel cylinders.When I put the fittings back on the front of the master cylinder it leaks between the washer and master cylinder and between fitting.
I did not have new washers or the fitting itself. I know I have the parts in the proper order. Any help would be appreciated
LP is offline   Reply With Quote
Old 04-03-2016, 12:31 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 53 Ford Master cylinder leaking
You can anneal the copper washer/s and re-use.
Heat the washer/s to red hot and immediately quench in cold water.
It may or may not do the trick but it has for me at various times.
Old 04-03-2016, 01:00 PM   #3
Barry-ct
Barry-ct's Avatar
Any decent auto parts store (napa, carquest )usually has an assortment of these copper washers. bring the old ones and match them up.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 04-03-2016, 02:03 PM   #4
FlatheadTed
FlatheadTed's Avatar
Check the mating face were the washer sits against ,that its square and smooth .Just done one that the casting was rough so we faced in a lath ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-03-2016, 07:34 PM   #5
Talkwrench
Talkwrench's Avatar
This maybe just the start of your problems.. Its great replacing wheel and master cylinders but remember its well over 50 years old and all those old brake lines are holding crap, this will now move into your brand new wheel cylinders and make sort work of them. Its well worth making new brake lines in older cars..
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 04-04-2016, 05:55 PM   #6
LP
I really appreciate all of the replies to my post. Now I have some things to try. I realize as Talkwrench said that this is only the beginning as this car had been sitting for many years. I will have many more questions, as this is my first flathead.
Old 04-04-2016, 06:47 PM   #7
Frank Miller
Frank Miller's Avatar
I had a bitch of a time with the one on my 49. Found a crack in the brass junction block.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 04-04-2016, 06:57 PM   #8
Barry-ct
Barry-ct's Avatar
Talkwrench has the right idea. Replace all the steel and rubber lines. Check the junction block for any cracks or imperfections. Replace anything you're in doubt of. Safety is the most important thing, for you and others.
Barry
50 F-1
Old 04-04-2016, 07:13 PM   #9
4dFord/SC
4dFord/SC's Avatar
Suggest wiring as the next item on your list. The safest route would be to replace it all.
4dFord/SC is offline   Reply With Quote
Old 04-09-2016, 08:45 AM   #10
ArcLighter
ArcLighter's Avatar
One of my next projects on my '53 will be:
DUAL BOWL MASTER CYLINDER CONVERSION part 1 of 3
DUAL BOWL MASTER CYLINDER CONVERSION part 2 of 3
DUAL BOWL MASTER CYLINDER CONVERSION part 3 of 3
ArcLighter is offline   Reply With Quote
