01-08-2020, 11:12 PM | #21 | |
Re: High compression head choice.
01-09-2020, 06:03 AM | #22 |
so does anyone offer the aluminum Lions head or Thomas?
every time I look, I see sold out. I want a head with a little wow factor. I attempted to buy a couple from someone on here I wont mention and I was left by the wayside- deposit and all, though I did recve a refund. wouldnt consider that route again. |
01-09-2020, 08:01 AM | #23 |
Question: I believe the 6:1 head is a little thicker than the stock and 5:1 head. If that is the case what studs would be used with 6:1 head? I know grade 8 but what length? A friend installed a 6:1 head on his engine and the nuts would barely go all the way on the stud..
01-09-2020, 10:08 AM | #24 | |
01-09-2020, 11:53 AM | #25 | |
01-09-2020, 12:04 PM | #26 |
Pouring Babbitt bearings is becoming a lost art. Should you over-stress your old bearings? |
01-09-2020, 12:08 PM | #27 |
The general consensus I've read seems to be that the max you should put on Babbitt bearings that have not been recently rebuilt is around 6.5:1, +/- 0.5.
01-09-2020, 12:12 PM | #28 |
Harpkatt, Your Winfield should give you good performance with no problems, just limit the spark advance because the higher compression will burn quicker than stock. If it is aluminum, it is a repro. I ran a Cyclone 7.5:1 crows-foot for many years and many miles with no problems. It is very similar to the Winfield crows-foot head. read my post above.
01-09-2020, 02:03 PM | #29 | |
That's good to know, perhaps my friend ran his studs in too far. I am moving up from a Snyder 5:1 head to 6:1. New build with babbit mains and inserted rods. Steve |
01-09-2020, 02:11 PM | #30 |
thx Alex!
01-09-2020, 08:23 PM | #31 |
I think Jim mentioned it earlier, to much advance will hurt babbitt quicker than anything. 26 deg. is plenty.
01-10-2020, 12:31 PM | #32 |
Babbitted main bearings do very well, I've run Bonneville at 167 mph on babbitt mains, still in good shape. Rods not as well but still no need to worry about them.
01-10-2020, 12:52 PM | #33 | |
David Serrano |
03-13-2020, 05:30 PM | #34 |
For those that have a Snyders 6.1 head are you torquing to 55 or 65 lbs?
03-13-2020, 07:44 PM | #35 |
TerryO, I have been running Brumfeld 5.9 heads for over 30 years now. Three different heads on three different engines. Still have one in a box to be put on my next engine build. Never had a problem with them. that i did not give to myself.
03-13-2020, 10:13 PM | #36 |
I have a brumfield and a 6/1 both are good running heads the 6/1 seems to have more lugging power
03-13-2020, 10:31 PM | #37 |
Building performance in any engine requires a balance.more compression? add more fuel,more exhaust better spark control...and a better cam.Look at it this way..a model a engine,stock flows at about 180 CFM..180 cubic feet of air flow. A stock Zenith,even a B zenith flows at about 80 CFM,your basically leaving half the fuel/air mixture out of the equation.Stromberg 97 flow rate matches the model A flow..compression increases are great but reduce your tolerance for timing deviation..in short,run a mechanical advance distributor,stop the hand work. Lastly,now that air flow ,compression and precise timing is nailed,open your exhaust some..
