10-27-2014, 02:49 PM | #1 |
1935 pickups
Ok pickup specialists ,what is the difference in cabs between the 1/2ton pickup and the 1 1/2truck,will the 1 1/2ton cab fit the pickup chassi?
10-27-2014, 03:17 PM | #2 |
Re: 1935 pickups
The cab will fit, the fenders are slightly different. There is no cutout at the front of the fenders for the bumper irons on the big truck.
10-27-2014, 03:23 PM | #3 |
Re: 1935 pickups
The big truck has the gas tank under the seat while the pickup has the gas tank at the rear of the frame under the bed as well.
10-27-2014, 03:31 PM | #4 |
Re: 1935 pickups
And short running boards.
The best way to have a friend is to be a friend. Howdy Doody |
10-27-2014, 11:06 PM | #5 |
Re: 1935 pickups
The fenders have a bigger radius than the pickup and the lower portion of the grill shell is narrower to accommodate the bigger fenders.
10-29-2014, 06:09 PM | #6 |
Re: 1935 pickups
10-30-2014, 12:03 AM | #7 | |
Re: 1935 pickups
11-02-2014, 12:00 AM | #8 |
Re: 1935 pickups
Here is a good thread on 35 to 37 pickup differences from the Hamb, which includes the differences between the big truck and pickup, including the grill she'll difference.
http://www.jalopyjournal.com/forum/t...masses.236409/ |
11-02-2014, 12:44 PM | #9 | |
Re: 1935 pickups
Take a close look at the first grille pics of the '35 and '36 PU's, you'll see the same difference at the bottom. I wish he would have used '36 PU and '36 large truck in the latter pics, but he used '35 PU. |
10-28-2014, 07:16 AM | #10 |
Re: 1935 pickups
The cabs will interchange but you will have to come up with an underseat pan and a seat riser if you want to convert the 1 1/2 ton cab to a pickup cab. There are various front sheetmetal parts that do not interchange including the fenders, inner fender panels, and running boards. The steering columns do not interchange, either. Good luck with your project.
11-02-2014, 02:45 PM | #11 |
Re: 1935 pickups
Lower portion of 35 and 36 PU grills are contoured the same except the 36 grill has 4 holes in the very bottom front for the under the grill panel to be bolted to the grill. 35 does not have these holes. Also the opening for the manual crank to slip through can be different sizes, some have 3 3/8" crank hole where some have 2 1/8" crank hole. This difference can be found on both the 35 and 35 grills.
