Old 08-23-2019, 05:52 PM   #1
coolcoupe
coolcoupe's Avatar
Default heater wiring
Have a 47 car and was wondering where the best way to place to get power to my heater ? Do I just get power from the ignition switch or from some other source ?
coolcoupe is offline   Reply With Quote
Old 08-23-2019, 06:42 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: heater wiring
These may help.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 08-23-2019, 08:46 PM   #3
alanwoodieman
do not take the power off the "coil" side of the ign switch. I went back to the circuit breaker under the dash and then routed it thru a fuse to the heater
alanwoodieman is offline   Reply With Quote
Old 08-24-2019, 12:18 AM   #4
coolcoupe
coolcoupe's Avatar
With the switch turn on, would that make the heater only work when the ignition is in the on position or on all the time ?
Old 08-24-2019, 07:51 AM   #5
jimTN
THANK YOU Forty Niner!!!!!!!!!!!!!! Included in that batch of information is the elusive code for wiring a 46-8 heater switch which a lot of us have been looking for.
jimTN is offline   Reply With Quote
Old 08-24-2019, 12:46 PM   #6
FortyNiner
FortyNiner's Avatar
Glad to be of assistance.
Old 08-24-2019, 01:46 PM   #7
19Fordy
19Fordy's Avatar
Not trying to be redundant but, here's more info.
https://www.earlyfordv8.org/forum/pr...=18&Topic=1692
Will the posting #10 help?
https://www.fordbarn.com/forum/showt...ht=wire+heater
Old 08-24-2019, 07:48 PM   #8
coolcoupe
coolcoupe's Avatar
Any problems with the power being hook up to the ignition switch ?
Old 08-24-2019, 09:13 PM   #9
JSeery
JSeery's Avatar
Heater and fans are high current users, why would you want to attempt to connect them to the ignition switch? The ignition switch is not designed to handle high current loads.
Old 08-25-2019, 06:08 PM   #10
coolcoupe
coolcoupe's Avatar
Thank you, JSeery thats what I was looking for. Moe
Old 08-25-2019, 06:54 PM   #11
coolcoupe
coolcoupe's Avatar
Just had a thought, how would you hook it up if a person wanted the heater to only work when the ignition was on ?
Old 08-25-2019, 06:56 PM   #12
JSeery
JSeery's Avatar
Relays, just like a fuel pump or something. Relays are handy little things for this type of stuff. Use a wire from the ignition switch as the trigger wire.
Old 08-25-2019, 07:05 PM   #13
meric42
meric42's Avatar
Here are the 1945 instructions, see the paragraph on switch connections. It tells you to connect to the red and black wire on the fuse block so the heater will only go when ignition is on. If you need this in higher resolution send me your email address and I can email it to you.
Hope this helps?
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 08-25-2019, 07:51 PM   #14
JSeery
JSeery's Avatar
It sure does say that!! The Red/Black wire is the wire from the ignition switch to the resistor on the fuse panel. I don't think that is a good idea at all!!! But, this is what the instructions say.
They say to connect to the Red/Black wire on the ignition switch for the Ford and to the fuse panel on the Merc.
