Old 06-21-2019, 06:57 PM   #1
coolcoupe
coolcoupe's Avatar
Default brake drums
I have a 47 car and wanted to know how many years of newer front drums that would fit?
coolcoupe is offline   Reply With Quote
Old 06-21-2019, 07:12 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: brake drums
48 ----some people have strange ideas of "will fit" though, baisically you are looking 42-48
Old 06-21-2019, 09:40 PM   #3
Sod Buster
Sod Buster's Avatar
I have a 47 and the drums hubs are what you have to watch when replacing, as the hub rides on the outside not inside.
Sod Buster is offline   Reply With Quote
Old 06-21-2019, 09:44 PM   #4
RalphM
RalphM's Avatar
If you want new drums go to boling brothers/ Mt products, they make great new brake drums for your car.
RalphM is offline   Reply With Quote
Old 06-22-2019, 02:05 AM   #5
Charlie Stephens
The attached photos are rear hub/drum assemblies. Pre war is on the left and post war on the right. Note the hub is inside pre war and outside post war. Either hub/drum assembly will fit '40-'48. Catch is you cannot use pre war hubs with post war brake drums and conversely. Also some post war hub/drum assemblies had weights welded on the drum that interfere with wire wheels. They need to be removed or relocated.
Charlie Stephens
Old 06-22-2019, 06:27 AM   #6
skidmarks
skidmarks's Avatar
42 to 47 half ton pickup is the same also
skidmarks is offline   Reply With Quote
Old 06-22-2019, 08:41 PM   #7
coolcoupe
coolcoupe's Avatar
Thanks Guys, now on the hunt !!
Old 06-24-2019, 01:10 PM   #8
Chris Haynes
Chris Haynes's Avatar
I am using 1940 Boling Brothers drums and hubs on '42-'48 backing plates.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 06-24-2019, 07:01 PM   #9
coolcoupe
coolcoupe's Avatar
Hi Chris, I will check that out.
Old 06-25-2019, 03:29 AM   #10
Ray Balukas
Ray Balukas's Avatar
I used J&G brake Drum relining , awesome job. They're on the web. Ray
Ray Balukas is offline   Reply With Quote
Old 06-25-2019, 09:37 PM   #11
mobileparts
I have the brake drums -- BRAND NEW -- and the brake shoes in ++ Asbestos ++...
Hope you have a U.S.A. address.... With the weight, the shipping into Canada would be astronomical.....
Always best to simply call me -- Craig -- 516 - 485 - 1935.... New York....
mobileparts is offline   Reply With Quote
Old 06-25-2019, 10:53 PM   #12
Tinker
Tinker's Avatar
Wish boling brothers/ Mt products... put out a wide five.
