01-28-2018, 04:05 PM | #21 |
Re: RHD Pitman arm
I used A Model A drag link on my 33 because it had a bolt on steering arm which is straight rather than the slightly angled forward stock arm. The Model A drag link is shorter than a 33/34 and does not put the steering on the sweet spot of the box in the straight ahead position. It was a bit out on mine and would be worse on a stocker. I replaced it with a made up adjustable drag link.
Mart. |
01-29-2018, 04:13 PM | #22 |
Re: RHD Pitman arm
OK DG & M ,thanks
01-29-2018, 04:30 PM | #23 |
Re: RHD Pitman arm
Thanks for your replies. Although I would have thought there’d be more RHD 1935/6s out there. When I dismantled my 35 phaeton for restoration it was noted that the drag link was making contact with the underside of the radius rod when on a lock. I have a theory this is why Fords decided to put a curved pitman arm on to lower the position off the drag link thus providing more clearance. Without more information or evidence of other 1935/6 vehicles fitted with this arm, it’s still only a theory
01-29-2018, 05:22 PM | #24 |
Re: RHD Pitman arm
Hi John,
I will be putting my 35 Phaeton together in the next few weeks and will give you some feedback. regards Viv. |
