05-25-2015, 12:10 AM | #1 |
10 spline to 6 spline drive shaft coupler
Have an overhauled diff. 4:11 with a 10 spline shaft to fit up to a 6 spline drive shaft. Old diff as removed a 6 spline, so the quick swap out delayed a little.
So the 10 spline to 6 spine adaptor will do the job? This is on a 38 PU. What was the standard set up? is the 6 spline set up for a car and the 10 spline for PU etc? Or is this in the transition period? Appreciate some advice. Thanks, Phil NZ |
05-25-2015, 12:15 AM | #2 |
Re: 10 spline to 6 spline drive shaft coupler
Hi Phil. In my experience the 6 spline was in both the car and pick up from 37 on and the most common pickup ratio was 4.11 The 6 spline was with the solid shaft and center bearing.Not sure about the 10 to 6 adaptor.Geoff
05-25-2015, 12:30 AM | #3 |
Thanks Geoff, as existing diff with the 6 spline has plenty of play and suspect brgs judging from oil as removed. Have an overhauled 4:11 and thought it was a straight forward swap. Have sourced a 10 to 6 spline from Ajay so hopefully this will do the job.
Thanks Phil |
05-25-2015, 08:11 PM | #4 |
Here is a picture of the adapter in place:
A good machine shop can do the change out. One of the best improvements I have made to the `35 was going to a 3.54 from a 4.11.
Son, you will never blow an engine up in high gear. |
05-25-2015, 08:13 PM | #5 |
Oops, read Shadetree's post wrong, thought he went from 3.55 to 4.11.
05-26-2015, 01:00 PM | #6 |
John |
05-26-2015, 02:56 PM | #7 |
Thanks for advice and info. Will be using it as a coupler.I have learned that the spline size changed from the 10 to 6 in late 1938. these being same for passsenger and PU.
This is the luck with older vehicles until they are actually opened up you dont really know what has been retrofitted over the years. Phil NZ |
