Old 07-02-2013, 12:38 PM   #1
Unshined2
Default holley 94 cast base pitting??
I have a couple of 94's with stuck and corroded throttle blades. I havent had them all the way apart yet. But I was thinking if they are corroded and pitted, is there a way to fix the pitting with and epoxy or other material. Of course being careful not to plug any holes and also careful honing after the epoxy cures...
Thanks
Unshined2 is offline   Reply With Quote
Old 07-02-2013, 12:52 PM   #2
Mike51Merc
Mike51Merc's Avatar
Default Re: holley 94 cast base pitting??
They're cheap and available, so there's no reason to try and reconstruct them with epoxy or JB Weld.
Mike51Merc is offline   Reply With Quote
Old 07-02-2013, 12:58 PM   #3
Unshined2
Are they sold as reproductions somewhere? I havent seen anything come up in an internet search or Fordbarn search, otherwise I wouldnt consider it.
Thanks again
Old 07-02-2013, 01:59 PM   #4
Ross F-1
Ross F-1's Avatar
Vintage Speed, www.vintagespeed.com
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 07-02-2013, 09:24 PM   #5
Unshined2
I may not have clearly asked the question. I was wondering about fixing the pits in the bases. I had already planned to get new throttle blades.
Old 07-02-2013, 09:45 PM   #6
Ross F-1
Ross F-1's Avatar
Vintage sells complete new aluminum or cast iron base sections, as well as blades.
Old 07-02-2013, 10:09 PM   #7
Unshined2
Ok. Thanks. Ill have to dig around some more on that site, couldnt find them on the first look.
