Old 03-01-2013, 12:25 PM   #1
Mtn Wudy
Mtn Wudy's Avatar
Default Horn Repair..
I'm inquiring here for my nieghbor...He has a nice 31 Roadster and has issues with the horn..Does anybody rebuild horn to make them "Goods as New"...?? He's not a hands on guy,,but wants it right..I'll help him ship it off to someone and put it back on....Can anyone point us in the right direction ??? Thanks ahead of time....Carl
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
Old 03-01-2013, 12:33 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Horn Repair..
Unless something is shorted or broken, most times all it needs is a few drops of oil on the two wicks, and a good cleaning of the commutator. My friend's was very slow until I removed the cover and held fine emory paper against the commutator while he pushed the horn button. After a few seconds the motor started to pick up speed and after about 30 seconds it was blowing like it should.
Also push the horn button and roll it around as you push in case it has a corroded connection to ground.
Old 03-01-2013, 01:36 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
HORNS
1. No known website: Model A Horns (231) 577-1375 (Michigan)
2. No known website: Bill Randall: (315) 336-8841
3. No known website: Neil Stegall: (601) 469-0878
4. No known website: Jim Diehl: (231) 577-1375
Old 03-01-2013, 02:08 PM   #4
30ccpickup
30ccpickup's Avatar
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 03-01-2013, 02:14 PM   #5
TinCup
TinCup's Avatar
Chris there you go showing off again.
TinCup is offline   Reply With Quote
Old 03-01-2013, 03:17 PM   #6
ctlikon0712
ctlikon0712's Avatar
Chris, if i were to save that GIF onto my computer just for my own purposes, what PC program should I use to play it?
Thanks a bunch.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 03-01-2013, 03:34 PM   #7
30ccpickup
30ccpickup's Avatar
It should play in Powerpoint. You can also open your web browser, click on file (upper left corner) and then click open.
Paul
