Old 09-17-2021, 08:23 PM   #21
Dougs 28
Dougs 28's Avatar
Default Re: Overheating 1930 Model A
Bergs, can’t go wrong, simply the best..!
Dougs 28 is offline   Reply With Quote
Old 09-17-2021, 08:44 PM   #22
Gufshoz
Gufshoz's Avatar
Do you have engine pans? I had overheating issues and went back to the pans and a new 2-bladed fan. Then I had a problem getting her up to operating temp (she ran at about 120*), so I added a thermostat and now she happily stays at 160*. My radiator is the original and has been boiled out and cleaned at a radiator shop. My coolant level stays just above the radiator fins and I use a 50/50 premix of antifreeze/coolant.
Good luck.
Gufshoz is offline   Reply With Quote
Old 09-18-2021, 03:35 PM   #23
Gene F
Gene F's Avatar
Gufshoz makes an interesting point. I have driven my A with engine pans, and without. Just seems to me like the pans help suck the heat out.
Gene F is online now   Reply With Quote
Old 09-18-2021, 03:52 PM   #24
GerryAllen
Joe, what i would do before I invested in a new radiator is flush your rad out. I flushed mine out with 3 gallons of vinegar by going for a 30 mile drive, Came home and drained it and used a 2 /3 vinegar to water, went for a drive and drained it and then did a 1/3 mixture and drained it. I then ran water through the rad, filled it with water and went for a drive. I repeated this three times and my water was finally clean after the last drain.
I bought a hand held heat sensor from Napa and shoot my temp regularly, i80 degrees is not out of line IMHO
Gerry Birch Bay WA
GerryAllen is offline   Reply With Quote
Old 09-18-2021, 06:05 PM   #25
1crosscut
1crosscut's Avatar
Joe before you invest in a new radiator make sure your timing is actually okay.
Your wrote in your first post that you thought your timing "seemed okay". Maybe re visit the timing again just to be absolutely sure. Timing can make a huge difference.
You've also posted that you have been shutting it down when your temperature gauge has reached 180 degrees. Take the cap off and place a dial meat thermometer directly into the coolant. You can drive with the cap off and with the thermometer in place. That way you can pull over when your dash mounted gauge reaches 180 etc... and check to see if the gauges agree.
Go ahead and keep driving it after reaching 180 and see just how hot it gets.
With the cap off you will see it starting to steam and boil over before things get too serious and damage your engine. (if radiator is too full it cam mimic an over heat / your gauges will tell you if that is the case) Just stay close to home and be willing to pull over and rest the engine for a bit if it actually does start to get too hot and boil over.
One more thing to check is for a failed head gasket. Remove the fan belt and watch the coolant for bubbles when revving the engine some. The kits to test for compression gasses in the automotive parts stores or online are fairly inexpensive and leave pretty much no question if you do or do not have a compression leak.
I think that there's a reasonably good chance you won't need to spend the money on a new radiator.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 09-19-2021, 06:44 PM   #26
JoeMarine
JoeMarine's Avatar
I'll flush the radiator tomorrow and check for bubbles before I do anything.
Thanks for the mentorship
JoeMarine is offline   Reply With Quote
Old 09-19-2021, 06:48 PM   #27
JoeMarine
JoeMarine's Avatar
Thanks Crosscut, I'll try those recommendations tomorrow.
Semper Fidelis
joe
Old 09-19-2021, 06:49 PM   #28
JoeMarine
JoeMarine's Avatar
Thanks Gufshoz, I do have the engine pans. I've had them on for over 6 years now.
Old 09-19-2021, 06:51 PM   #29
JoeMarine
JoeMarine's Avatar
Urrrahh, thanks Jayvee34, I'll run it to see what my max temp is tomorrow and let everyone know. Thanks again for the advice.
Semper Fidelis
Joe Marine
Marine
Always
Old 09-19-2021, 06:52 PM   #30
JoeMarine
JoeMarine's Avatar
Thanks Old31
Old 09-19-2021, 06:53 PM   #31
copgib
copgib's Avatar
JoeMarine, from an old retired Navy man, I would recommend a Berg Radiator. I was given the same advice when I had a overheating problem with my 1930 Model A Coupe. A Bergs Radiator has never let me down and I highly recomend one if you are in the budget for it. Take care shipmate. Hugh
copgib is offline   Reply With Quote
Old 09-19-2021, 06:53 PM   #32
JoeMarine
JoeMarine's Avatar
Thanks Illinois John.
Old 09-20-2021, 11:45 AM   #33
katy
katy's Avatar
Originally Posted by nkaminar View Post
With my heat gun I measured 170 degrees at the head and 200 degrees at the pan while the temperature gauge installed in the output neck measured 140. This was while driving at 45 on a level road in summer.
That's a good trick.
Water boils @ 212 degrees, 180 is considered normal, when it starts getting 200 and rising I would get concerned. If it is not steaming or blowing hot water out of the overflow or the cap and temp is below 200 I would not consider it to be running hot.
Ditto
Old 09-20-2021, 12:43 PM   #34
jerrytocci
Disconnect bottom hose and plug inlet with a rag . Run garden hose into filler and see that it flows right through. Hold hand over bottom and fill and remove hand and water should gush out.
jerrytocci is offline   Reply With Quote
Old 09-20-2021, 12:43 PM   #35
jerrytocci
Do same with block
Old 09-20-2021, 06:34 PM   #36
JoeMarine
JoeMarine's Avatar
1CrossCut, Jayvee34, Gufshoz, Gene and the rest of the professionals on line . . . thank you again.
I took all your advice and here are the results:
Drove the car for almost one hour.
Put a meat thermometer in the radiator neck and the highest the temperature ever got was around 195 . . . both at the neck and on the gauge I've installed.
I also checked to see if any bubbles were 'percolating' with the cap off . . . never saw any bubbles so I believe the gasket on the head is okay.
I still haven't flushed the system but will do so next week.
All that said, you all saved me big bucks. I don't plan to buy a radiator for now.
I'm hoping after I flush the system the temperature will be a little less than 195.
Looking forward to driving the vehicle further and longer than before.
Again, many thanks to you all.
God Bless and Semper Fidelis
Joe Marine
Marine
Always
Old 09-20-2021, 07:38 PM   #37
1crosscut
1crosscut's Avatar
Glad your gaining on it.
When you flush the radiator most do so to try to get out rust. First use Simple Green or some dishwasher detergent to get the grease (usually from years of excess greasing of the water pump) out that may be coating things.
After that go after the rust.
Old 09-21-2021, 10:27 AM   #38
katy
katy's Avatar
If one uses dishwasher detergent to clean the cooling system be sure and get the low sudsing type. Don't ask.
Old 09-21-2021, 01:18 PM   #39
1931 flamingo
1931 flamingo's Avatar
IF the water looks rusty BEFORE draining if you have a concrete driveway, drain it in the street or on the grass. Concrete will most likely stain. FWIW
Paul in CT
Old 09-21-2021, 10:29 PM   #40
jerrytocci
Rear water jackets around # 4 have a tendency to store egg corn shells . The head does so as well . And...No ! I do not have a clue how those nuts and pieces of seat material gets in there
