Old 08-06-2014, 02:56 PM   #1
firetique57
firetique57's Avatar
Default Spring shackel question
I've installed new spring shackels front and rear. I've noticed the bolts on all go well past the cotter key hole. If I install the castle nut up snug so as not to bind the up and down movement of the shackel the cotter key doesn't engage the nut as it should to keep it from turning. Are the nuts to be installed in such a way as it allows front and back movement as well as the up and down?
firetique57 is offline   Reply With Quote
Old 08-06-2014, 03:13 PM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: Spring shackel question
are you using REPOP Shackles or Originals.. I Hope Originals so they fit like they should??
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 08-06-2014, 03:20 PM   #3
ford3
with repos you have two choices, redrill the hole in a different place and shorten bolt, or use washers to take up the spare length
ford3 is offline   Reply With Quote
Old 08-06-2014, 05:00 PM   #4
firetique57
Yeah, they are after market not original. I think some washers are the answer. This is a driver not a points car so it won't matter much to me.
Old 08-06-2014, 05:42 PM   #5
msmaron
msmaron's Avatar
It does matter....find originals, if it is a driver don't you want to be able to drive totally safe!??
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 08-06-2014, 05:46 PM   #6
700rpm
700rpm's Avatar
I have heard of repros being prone to breakage. If you use them, carry spares.
Ray Horton, Portland, OR
