10-02-2021, 06:22 PM | #1 |
1938 60 HP Drive shaft
Could someone enlighten me if all drive shafts for torgue tubes are the same diameter or is the infamous 60hp drive shaft a smaller diameter. Thank you
10-03-2021, 01:31 AM | #2 |
Re: 1938 60 HP Drive shaft
No help for quite a while, so I will speak up. Never played with a 60, but since the front u joint is the same as v8's, and the rear differential parts are the same, I have to conclude the shaft is the same too. Length? now that could be different. I have a 60 trans on hand, will measure against a v8 in the morning if no one else pipes in, but I bet its all the same
10-03-2021, 09:23 AM | #3 |
