02-23-2021, 12:31 PM | #1 |
Uploading pictures
I can’t seem to upload pictures. I was wondering if it’s because I’m new or maybe because I’m seventy. I sure enjoy seeing photos of other members projects. I have followed the instructions and picked photo from my pictures but they won’t upload.
02-23-2021, 12:38 PM | #2 |
Re: Uploading pictures
The problem that is most encountered is that the pictures are at too high in resolution.
You have to determine if you can set your picture taking device to the lowest resolution or use a program to do so to existing pics.
02-23-2021, 01:08 PM | #3 |
If your using windows download Photoscape
http://www.photoscape.org/ps/main/download.php It lets you save pictures in lower resolution. If you are using an iPad just crop them in Photoeditor (need to get the app) This usually makes them small enough to load. Some people have good luck emailing the pictures to themselves it usually resizes them also. Hope this helps. |
02-23-2021, 01:44 PM | #4 |
Windows users have a built in app called PAINT. It has the ability to resize photos. .JPG's need to be about 1.4Mb or smaller, I usually set the pixels to about 2400 in the larger dimension.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
02-23-2021, 04:13 PM | #5 |
I have never been able to load photos that large and that is way above the limit stated in the pop-up, which is 585.9 KB. May depend on how you are posting them, I use the thumbnails, and this is the limit I use.
02-24-2021, 08:00 AM | #6 |
https://www.fordbarn.com/forum/showthread.php?t=246769 I resized the pictures in the link above using Photoscape on a Windows computer, they were all done at once using the bulk resize setting. Last edited by corvette8n; 02-24-2021 at 08:12 AM. Reason: Added info |
02-24-2021, 01:23 PM | #7 | |
https://www.fordbarn.com/forum/showp...15&postcount=9 full thread: https://www.fordbarn.com/forum/showthread.php?t=294363
02-24-2021, 01:29 PM | #8 | |
02-23-2021, 02:19 PM | #9 |
Here are a couple of posts I made, one for windows Paint and the other for an iPhone. You are not alone with this issue!
https://www.fordbarn.com/forum/showp...1&postcount=16 https://www.fordbarn.com/forum/showp...76&postcount=5 Glenn |
02-23-2021, 03:18 PM | #10 |
Thanks for the help. I need to learn more stuff. I’ve been taking pictures with an iPhone and air dropping them to my iPad. Once again I appreciate your wisdom.
02-24-2021, 01:41 PM | #11 |
Hi Everyone, One of the less-used forums around here is the Test Forum.
I used it to experiment with resizing the same pic until the file wouldn't upload.
