Old 04-10-2015, 07:20 PM   #1
briphaeton
Default clutch fork busted
I pulled my engine today because of clutch problems and found the clutch fork had one arm broken off. This is the first time I've seen this happen. My other car is having a similar problem and afraid to drive it much out off town.
Brian
briphaeton is offline   Reply With Quote
Old 04-10-2015, 11:00 PM   #2
Dave Mellor NJ
Default Re: clutch fork busted
It's a fairly common A quirk. They usually break right at the cross pin hole. Old timers kept a spare.
Dave Mellor NJ is offline   Reply With Quote
Old 04-11-2015, 12:18 AM   #3
RandyinUtah
If the old times kept a spare is something that can be changed without pulling the transmission?
RandyinUtah is offline   Reply With Quote
Old 04-11-2015, 09:06 AM   #4
RonC
RonC's Avatar
I never heard of anyone breaking a clutch fork? Do you mean clutch lever?
RonC is offline   Reply With Quote
Old 04-11-2015, 09:26 AM   #5
briphaeton
Not the lever or arm, It's the fork that pushes the throw bearing forward. By the way I also carry a clutch arm (lever) while out of town.
Thanks
Brian
Old 04-11-2015, 12:00 PM   #6
Big hammer
I have changed gears not using clutch 2nd to 3rd easier than 1st to 2nd
going into 1st or rev no way You might put into the gear before starting engine and then
bang into gear to get you home. Not for daily use but just to get you home
Old 04-11-2015, 11:33 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Don't see how.
Old 04-12-2015, 09:55 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I have a spare fork that has a crack at the keyway. It isn't completely broken, but will never be installed.
Old 04-12-2015, 10:58 AM   #9
Pilotdave
Pilotdave's Avatar
I suppose that a very patient person could change that fork without removing the engine and flywheel. You'd have to "operate" through the inspection opening - and be able to drive the old pin out, then pull the shaft out the side of the housing (hoping that the fork will slide off Woodruff key), then reverse the process including driving in a new pin!
I just replaced the fork and shaft in my Tudor. They are the newer versions of both. Both are repro parts. No Woodruff key but a larger diameter pin. The arms on the fork had a flat surface and a rounded surface. The fork should be installed with the rounded surface against the shoulders on the throwout bearing casting.
Pilotdave is offline   Reply With Quote
Old 04-13-2015, 05:25 PM   #10
briphaeton
I would say it's almost impossible to change the fork unless you pull the engine. I had to use a hammer to tap the fork off the shaft. Tom Endy wrote a article about the service bulletins getting it wrong. Ford possibly changed the fork design with the 5/16 pin in June 1929.
