Old 09-07-2021, 06:54 PM   #1
36FiveWindowCoupe
Default 1936 Ford and 1940 wheel hubs
Hi, I have two 36 fords. Love em… I am rebuilding the five window coupe and have a few questions.
I am keeping it fairly stock with mechanical brakes but want to run modern wheels and tires. (not the wide fives on this one) My question is, will 1940 wheel hubs fit the 36 spindles and rear axles, and will the 40 brake drums fit as well??? THANK YOU for any help.
John
36FiveWindowCoupe is offline   Reply With Quote
Old 09-07-2021, 07:08 PM   #2
bbrocksr
Default Re: 1936 Ford and 1940 wheel hubs
John
No on the front, different offset for the drum . Yes on the rear.
Bill
bbrocksr is offline   Reply With Quote
Old 09-07-2021, 07:52 PM   #3
Brian
Brian's Avatar
1935 front drums will fit 36 spindles and have the same bolt pattern as 1940. you will have to do some slight modifications, but dead easy
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 09-07-2021, 10:11 PM   #4
36FiveWindowCoupe
Thank you Brian...the problem is finding good 35 drums.
Old 09-07-2021, 10:14 PM   #5
36FiveWindowCoupe
What are the "slight modifications" Brian from NZ
Old 09-08-2021, 12:00 AM   #6
Brian
Brian's Avatar
The slight modifications are; to fit 40 Ford wheels to 35 drums, one needs to remove the 5 nubs inboard of the studs, in order the wheels can fit properly. The reverse of using 40's drums with wires, where spacers must be fitted in order to fit 35 wires.
Old 09-08-2021, 12:38 AM   #7
V8COOPMAN
V8COOPMAN's Avatar
There is a "no brainer" answer to this. Swap '37-'40 spindles onto your '36 axle. It's a "bolt-on" if you use king pins matching year of spindles. Even the tie rod and drag link will bolt-up! Easy-peasy!!
We're swapping '40 drums onto a '37 Coupe as we speak, to get rid of the wide-fives and make tire selection much easier. You can bolt-on '40-'48 16" wheels and caps, or in our case, 15" early F-100 wheels which take the same '40-'48 hub caps. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-08-2021, 01:42 AM   #8
deuce lover
deuce lover's Avatar
Found you a nice pr of 35's.PM sent.
deuce lover is offline   Reply With Quote
Old 09-08-2021, 02:00 AM   #9
Brian
Brian's Avatar
Coop, the op wants to retain mech brakes. What you're suggesting won't work!!
Old 09-08-2021, 05:38 AM   #10
V8COOPMAN
V8COOPMAN's Avatar
Man, I just read right past that one like I had a clue! I apologize, guys!! What do I know? DD
T5 W/TORQUE TUBE
Old 09-08-2021, 06:28 AM   #11
36FiveWindowCoupe
Thank you...
