Old 11-30-2020, 01:34 PM   #1
old31
Default 35 Ford door pull handle
Does anyone have a pic of how and where this door pull handle gets installed?
old31 is offline   Reply With Quote
Old 11-30-2020, 05:08 PM   #2
Tom-MI
Tom-MI's Avatar
Default Re: 35 Ford door pull handle
This should be easy.
Remove the window frame and pull back the top of the door panel about an inch. You should see two raised humps in the door metal with holes. shove nails through the door panel to mark each hole. Use 1/8"x 3/4" oval-head sheet metal screws to attach the robe. Sometimes the holes have been enlarged over time requiring a wider screw. If painted I use a dish washer/cup between the screw bottom and the rope end piece to avoid cracking the paint.
Tom-MI is offline   Reply With Quote
Old 11-30-2020, 05:14 PM   #3
Don Rogers
Don Rogers's Avatar
Here's a few photos of the pull cords installed. I believe that they were installed with oval slotted machine screws.
Don Rogers is offline   Reply With Quote
Old 12-01-2020, 07:31 AM   #4
oldbugger
oldbugger's Avatar
May I ask where you got the door pulls, and do you like the quality. Paul
oldbugger is offline   Reply With Quote
Old 12-01-2020, 08:49 AM   #5
old31
The quality is great.
https://www.ebay.com/i/254661273740?...SABEgLwafD_BwE
Old 12-01-2020, 09:01 AM   #6
old31
I am surprised with the angle of your armrest. Is your car a 35? Is that correct?
I was going to install my new armrest in a straight line, parallel to the top of the door frame.
Old 12-01-2020, 08:16 PM   #7
rich b
rich b's Avatar
Were there two possible positions for the pull? From the looks of the holes it was originally in rearmost position (yellow circles).
Old 12-02-2020, 02:01 AM   #8
Tom-MI
Tom-MI's Avatar
I can't speak for others with arm rest locations but with every stock '35-'36 I have seen has a rectangle hole cut into the door metal for the arm rest clip to hang on. Unless you cut a new location for the hook to grab you are stuck with the angular location.
